A great new review from Part Time Audiophile!!!
Started by Triode Pete, February 16, 2025, 09:50:22 AM
Triode Pete
A new, great review from Part-Time Audiophile's Editor-in-Chief Marc Phillips!
https://pt.audio/2025/02/16/triode-wire-labs-power-cords-review/
Triode Wire Labs Power Cords | REVIEW
By Marc Phillips
February 16, 2025
It?s 2025, and I?m wondering what audiophiles think about power cords right now. It?s been a roller coaster ride over the years, starting with ?the power company sends the current miles away to your house, and you think the last two feet can make a difference?? and then moving to ?I tried putting a $500 power cord in my $1000 system and it didn?t make a lick of difference? and then to ?why the heck are there such things as six-figure power cords?? before we wind up at a crossroads, the place where we finally say ?okay, maybe there?s something to this power cord stuff.? I like to think I?ve learned a new thing or two about power cords in the past couple of years, mostly in controlled A/B comparisons, which is why I instantly agreed to reviewing three new Triode Wire Labs power cords?the ?Eleven Plus? American Gauge (from $299 each depending on length), the ?Nine Plus? American Gauge (from $499 each), and the Digital American II (from $549 each).
When I said I learned a few new things about power cords in the last couple of years, that goes back to my visit to Audio Group Denmark in the summer of 2022. First, if you want to put a single expensive power cord in a modest system for maximum impact, the right place to put it is in the AC wall outlet. Maybe it goes from the wall to a power conditioner, or maybe it goes straight into your amp. But it?s the first one. If you ever visit the good folks of Aalborg, they?ll A/B power cords all day long if you let them. For me, this is where a single power cord can make the biggest difference in a system?s sound
Second, there are other variables that can affect the performance of a power cord. Did you know the length of the cord matters, and not in the direction that you think? In another A/B comparison, I compared the sound of identical power cords at 2m and 4m lengths. With the longer cord, the system sounded more quiet and open every single time. I?ve heard a couple of explanations for this, but my guess is that many cable manufacturers use some sort of insulation or noise reduction material or little black boxes attached to the actual cable with all sorts of proprietary goodies stashed inside. The longer the length of the power cord, the greater the opportunity to lower the noise floor. The more you think about that, the more you?re willing to dismiss the ?miles and miles of current? argument.
This is where Triode Wire Labs comes in. When ?Triode Pete? Grzybowski sent me an email announcing his three new Triode Wire Labs power cords, and asked if I could arrange a review with one of the PT.Audio staff, I connected all of the aforementioned dots and stepped up and proclaimed that I, and I alone, will take on this noble challenge. I know that the best way to compare three different power cords and their effect on a hi-fi system?s sound is to swap them at that very first spot, the wall outlet. I also know that hearing big differences is easier when your gear has plenty of resolution, a contentious point within the audiophile community that seems to suggest, ?Them?s the breaks, so maybe you should start brown-bagging it to work!? The Triode Wire Labs power cords will have all the support they need for this test?plenty of stellar gear, and grounding devices and power conditioners as far as the eye can see.
That brings up one more variable for the Triode Wire Labs power cord evaluation. Triode Wire Labs has built their reputation on American-made cables and power cords that sound fantastic for a very affordable price. Whenever I?m tasked with reviewing an affordable or ?entry-level? product, I sometimes judge its performance by how it compares to some of the more expensive examples I have at the time. In other words, I look for what?s missing. (Just a side note: while Triode Wire Labs features cables that are within the reach of most audiophiles, Triode Pete does make cables that are more ambitious and costly?but not insanely so.) When an entry-level product does well in these comparisons, it?s usually because those losses are minimal. But this is Triode Wire Labs. I?ve heard these cables and power cords perform at least fifteen or twenty times at high-end audio shows, usually with Volti Audio speakers and BorderPatrol electronics. These are not entry-level systems by any means, and I?ve included them in many of my Best of Show reports.
In other words, I?ve always wondered how Triode Pete does so much for so little. Now?s my chance to geek out in my cable laboratory and find out.
Inside the Triode Wire Labs Power Cords
First off, let?s take a look at Triode Pete. I?ve seen affordable cables assembled by questionable sources using questionable practices?stock Belden cables with fancy new jackets, stuff bought on the cheap overseas and marketed as truly innovative, and more. Pete, on the other hand, is a licensed professional engineer with degrees from Clarkson University and the New York Institute of Technology. He spent 33 years in the power generation industry, as chronicled in the bio on his website:
?Pete has gained considerable experience and knowledge in electrical theory and construction. Experimenting with DIY power cables, speaker cables as well as interconnects, Pete constructed numerous variations and configurations with different metals as conductors, assorted construction techniques, various stranding sizes, different twist lengths and insulation, as well as grounding and shielding techniques. After all this experimentation, he found a material and construction combination that worked ?best? for hi-fidelity audio applications that also could be assembled for affordable audiophile prices.?
Among these three Triode Wire Labs power cords, all supplied in six foot lengths, the most affordable is the ?Eleven Plus? American Gauge. This is a power cord that uses IeGO Furukawa copper connectors and has been ?cryogenically treated with passive filtering.? I?m already an owner/user/fan of Furutech cables and connectors, as well as NCF noise suppression products, so seeing these connectors on the Triode Wire Labs power cords was a great start. The "Eleven Plus" is indeed the entry-level power cord from Triode Wire Labs, but it now features enhanced geometry that is patterned after the Obsession NCF, Pete?s $1,499 flagship power cord.
The second Triode Wire Labs power cord is the ?Nine Plus? American Gauge, which replaces the IeGO Furukawa copper connectors with the same Furutech FI-11 copper connectors that I have on many of my expensive Furutech cables. It also features the new geometry from the Obsession line.
The most expensive of the three Triode Wire Labs power cords is the Standard ?Digital American II? Series, which looks far more upscale than the first two cords. The Digital American II has been cryogenically treated with conductive gold Mylar and Conductive Carbon Fiber shielding, and it uses the IeGO pure copper connectors that have been housed in carbon fiber ?Lightning? shells. While the Nine Plus and the Eleven Plus look far more substantial and serious than any stock power cord, it is the Digital American II that looks and feels like a very expensive power cord. Plus, I love the sparkles on the cable jacket, which assumes sort of a mid-Century look in the right light.
I was curious about the ?digital? moniker for the more expensive Triode Wire Labs power cord, and Pete has designed this ?standard? version to focus on hi-rez digital components such streamers, servers and DACs. There is another version of this power cord, the HP Digital American, that is suited for power amps, power conditioners and other types of power regenerators.
Set-Up
Since I?m tackling a direct comparison between three different Triode Wire Labs power cords, I did my absolute best to maintain rigor throughout the review process?well, enough to hear differences without driving myself crazy over testing protocols. Each of the three Triode Wire Labs were plugged between the AC wall outlet, which has recently been upgraded with the Furutech NCF power receptacles and outlet covers, to the Telos Audio QRC Quantum Resonance Conditioner.
The rest of the system remained untouched during the comparisons: J. Sikora Initial Max turntable with two KV12 VTA tonearms, the Aidas Cartridges Tru-Stone Gold Web MC cartridge, the Allnic Audio H-10000 phono preamplifier, the Vinnie Rossi Brama 2 integrated amplifier, and the YG Acoustics Talus loudspeakers with the YG Descent subwoofer. The other power cords in the system were a combination of Furutech NCF, AudioQuest NRG and Cardas Audio Clear Beyond. Additional grounding was accomplished with the Telos Audio GNR and the CAD Ground Control GC1.1 earthing devices.
I was hoping to use the formidable $25,000 Telos Audio QBT cable burn-in box for this review, but Pete offers a free preliminary burn-in with Alan Kafton?s excellent audiodharma CABLE COOKER. Still, I couldn?t leave well enough alone and I still ran the Triode Wire Labs power cables through the Telos device. While I?ve consistently experienced a huge difference in the sound of cables I?ve run through the Telos, this was the one time where I heard very little difference before and after. So Kudos to Alan and Pete for a thorough burn-in.
Finally, the three Triode Wire Labs power cords took turns in the system. I let each power cord settle in for a few days, and then I listened for a few more. Then I removed the Triode Wire Labs power cords and placed my reference ?first power cord,? the Furutech NCF, to recalibrate my ears. After a few rounds of this, I started hearing the contributions of each of the power cords on a fairly reliable basis.
The Sound of the Triode Wire Labs Power Cords
What does a ?good? power cord sound like? I?m hoping that as an audiophile, you already know the answer to this. A good power cord, just like any cable, should have no sound. So when I listened to each of the Triode Wire Labs power cords, I paid attention to any changes I heard?an increase in the noise floor, or anything else that seemed amiss. Once again, we?re talking about ?letting more music through,? which means you should hear deeper into recordings.
First of all, the Digital American II power cable outperformed the Nine Plus and the Eleven Plus by a noticeable margin. The differences between the Nine Plus and the Eleven Plus were smaller and more subtle, and if I was a prospective owner I might balance the small gains delivered by the Eleven Plus against the added cost. (Not to sound too snobby, but with a more modest system you might struggle to hear a difference at all.) If I was that customer, however, my decision would be clearer once the Digital American II entered the arena. You want gorgeous, black silences between the notes? The Digital American II has them in spades.
That seems to suggest that the two more affordable Triode Wire Labs power cords underperformed in some way, and that?s not what happened. The Nine Plus and the Eleven Plus power cords simply didn?t draw attention to themselves, especially in the context of a system populated with a number of costly power cords (which probably average in the $2,000+ range). This is where it gets a little tricky, since the better power cord shouldn?t impact the sound in a noticeable way. It should, instead, preserve the sound you?ve already achieved through the selection of your system?s main components. But when I used the Nine Plus and the Eleven Plus in my system, they seemed to fit right in without drawing attention. When the Digital American II was in the system, however, I heard a distinct lowering of the noise floor every single time. I noticed those darker silences, I noticed those sharper transient edges, and I heard a musical presentation that sounded relaxed and free from congestion.
I found YuWen Huang?s ?women only to be a superb test disc for these comparisons. This collection of solo piano pieces reveals so much about the performer and her chosen instrument, about the way she works the pedals and the way the flow of the music is connected to her physical movements. I also heard more of the piano itself with the Digital American II, those echoes and reflections and decay you should hear from the innards of a big wooden box filled with metal wires. To put it simply, I noticed far more of those spatial cues and those details that combine to sound natural, like the real thing. I felt that I could place the Nine Plus and the Eleven Plus power cords into any system and probably not think about them afterward, what they?re doing or not doing, but if I was searching for a few power cords for an entire system, I would choose a fistful of the Digital American IIs and go on living my best audiophile life.
I did mention a slight difference between the Nine Plus and the Eleven Plus power cords in my reference system. It came down to a relatively simple observation, that the Nine Plus provided a slightly larger soundstage that stretched out in multiple directions. How small was this difference? I wouldn?t even notice there was an issue with the soundstage dimensions if I wasn?t conducting endless A/B comparisons over with the three Triode Wire Labs power cords. Here?s the easiest way to illustrate the quality of these power cords?after the formal A/B comparisons were complete, I continued to use the Triode Wire Labs power cords wherever I needed them in the system, and I stopped noticing what they did or didn?t do, which is probably an effective way to judge the Nine Plus, Eleven Plus and Digital American II.
I?ll say this once again: I would happily install Digital American II power cords in my reference system and never look back. I would happily use the Nine Plus and the Eleven Plus for second systems, such as when I build a headphone-based system or a desktop system. With the Triode Wire Labs power cords in any of my systems, I felt utterly confident they were doing an excellent job?both ?for the money? and otherwise. I know Triode Pete is proud of the value of his products, but there?s a point where I have to stop talking about affordability. There are very few compromises here.
Conclusions
I?ve taken on a number of ?affordable? cable reviews in the past from such companies as Raven Audio, Core Technologies and Luminous Audio Technologies, and I have to admit it?s exciting to recommend a contentious product like a power cord that doesn?t cost more than most people?s complete hi-fi systems. When I was a journeyman audiophile, I was always on the lookout for inexpensive ?audiophile grade? power cables because, quite frankly, I was unsure of the potential benefits in my modest system. On a few occasions, I was in desperate need of a specific cable and it was like pulling teeth?how can I be happy with something I can afford? I?ll admit to buying those 50′ spools of speaker wire from Radio Shack back in the day just to solve an immediate problem.
If I?d known about Triode Wire Labs back then, I would have pulled that trigger and I would have been proud to tell my audiobuddies about my smart buying habits. For me, the Triode Wire Labs power cords offer something a little more. Perhaps it?s because Triode Pete is a truly honest manufacturer who really wants his customers to appreciate both great sound and a wise investment. For me, using these power cords in a system that retails for well above the six figure mark was enlightening. Not once did I feel the need to swap out power cords because I was ?missing something.? That?s why the Triode Wire Labs power cords, especially the Digital American II, earn my highest recommendation.
Finally, if you want to read Grover Neville?s excellent survey on an entire loom of Triode Wire Labs cables, click here.
Thanks, Marc!!!
Cheers,
Pete
Thanks, for posting, Pete!
What a fun and comprehensive review. It has been quite a learning process for me, even though I started getting into higher end audio in the 80s. But it's only within the last few years that I added the UberBUSS and then your Digital American II within the last year or so. What a great difference giving the UberBUSS some extra help to really get the system noise free. No more waiting for 9:00 pm for good sound and midnight for great sound. The best way imho to get great performance is to go after noise from the source and that has also allowed my mostly modestly priced gear to really perform at great levels 🎶
Spiritual Sound complete loom
JPLAY, Tidal, Qobuz
