Author Topic: New Reference Linestage - one of a kind- built for you -based on Purity  (Read 4105 times)
Offline Response Audio
    • Response Audio
As many of you know, I was one of the partners and designer for Purity Audio Design. One of our most popular products was the Reference and Statement preamplifiers.
We have two of the latest chassis? for this unit still in stock which we can build as the original or custom built to fit your needs.
Please see our web site for full details: https://responseaudiony.com/the-original-reference
Design Engineer
Response Audio NY
Custom Vacuum Tube Deaign
www.ResponseAudioNY.com
    • Response Audio
Re: New Reference Linestage - one of a kind- built for you -based on Purity
« Reply #1 on: November 23, 2024, 10:15:56 AM »
Save $5,000 on the original design or choose your own features. We can build with your choice of volume components, coupling capacitors and solid state or tube power supply.
We can also build the original Statement linestage with dual mono external power supply. Starting at $12,250. This is the pieces that was reviewed in The Absolute Sound several years ago.
The Original:
Zero feedback design
- Transformer coupled balanced input
- Transformer coupled balanced output
- Dual triode 6SN7 signal tubes
- Bent Audio relay volume control
- Central one-point star earth grounding
- Separate transformer and power supply for remote system
- Laser engraved front, rear and top panels made
- Top quality input / output single ended RCA and XLR connectors
- Line Inputs - 6 sets - 3x Balanced / 3x single ended
- Line Outputs - 4 sets - 2x Balanced / 2X single ended
Analog components:
- Clarity Cap MR coupling capacitors
- Balanced input transformers
- Balanced output transformers
Power Supply components:
- Polypropylene storage capacitors
- Choke filtered
- High current "Ultra Fast - Soft Recovery" diodes
- Separate, dedicated power supply for remote unit
- Copper lined
Original Selling Price $14,995
Design Engineer
Response Audio NY
    • Response Audio
Re: New Reference Linestage - one of a kind- built for you - ONLY $7,495
« Reply #2 on: November 26, 2024, 08:04:26 AM »
Original Reference only $7,495 :roll:
We are trying to move all Purity Chassis inventory ASAP to make room for 2025?s lineup.
Design Engineer
Response Audio NY
