Can't fight City Hall syndrome now. I'm going to live with the microphonics "as is", since it's somewhat stable situation as long as I don't tap/rock the platform/chassis.
I've played with "doctoring" the sound quality. In the end, I think I like it "as is" also, without any Vibrapods, etc., underneath. The Vibrapods killed the sound quality IMO. The foam was slightly better, but.... still the sound didn't thrill. Also, I came across some ceramic door handles/knobs the other day. I took out the screws, and stuck them underneath the amp. Believe it or not, the sound was pretty good. Shiny, punchy.... But, I still found it not that musical to my taste. If you twist my arm and choose I'd take the ceramic door handles/knobs.
WITHOUT anything, the sound is actually MORE organic, more musical to my taste. I was told that wood may be THE answer. I'm trying to get someone to "make" some Ebony cones for me.
NO Herbies. They're too pricey. I actually bought some parts from Home Depot, see if I can make something similar, O Rings and Washers, from the Plumbing department. Didn't go through with it. I am staying with the teflon tube dampers from eBay. Cheap enough.
All in all, without anything underneath, the sound is more preferred. Is this what they "the more they change, the more they don't change..."?
