Still tweaking… Had a couple of people over and they gave me some things to consider and things to try.
I had initially modeled my second sub settings on the initial one I had.
After careful analysis with an SPL meter and test tones, it became apparent that one sub had significantly louder db levels because of its placement in the room. I’m talking 10-11 db louder!
I addressed that, and the sound improved.
My guest also felt that a closer listening position sounded better- he was right, and my listening chair is now two feet closer to the speakers. I rarely listen ‘critically’, and rarely sit in this chair, but the difference was significant enough to make the change permanent.
Today, I broke out the meter again to experiment with phase settings… Much to my surprise, even though the subs are up front and facing the same way as the mains, the 180 degree phase setting had about a 2-3 db higher output than 0 degrees. I never expected that. I used tones just above and below 50Hz, where I have my sub’s crossover set.
I’d say the sub tweaking yielded 5-10 per cent better sound, and the chair movement, when listening critically, as much or more.
“We suffer for our craft,” as my guest jokingly said.
