Something I changed, actually testing right now is lowering the filament voltage and checking
tube life of the JJ E88cc tube. With today's tube prices, would like to obtain maximum tube life.
Lowering filament voltage too much will cause premature tube failure. I am thinking that the
ratio of actual idling plate current vs the maximum listed in the particular tube specs will
determine how low the filament can go. However, this could be wrong due to an assumption
I am making.
A 12ax7 has a maximum plate current of 9ma while typical idle is listed as 1.2ma.
or 13.3%
A 6dj8, E88cc has typical idle plate current of 15ma while maximum of 20ma, or
75%.
Both are running the plate current and other characteristics in the linear region.
I have seen an ARC SP-3 preamp running the 12ax7 filaments nearly dark with
low filament voltage as there is plenty of reserve cathode current capability according
to the specs in the manuals.
I am testing the JJ E88cc for optimum tube life at ~8.6ma, plate current each section
or 43% of the maximum listed plate current.
Rewrote this post due to parts on hand for a small test chassis. The 11A preamp will take
much longer to evaluate while the small chassis will be on 24/7.
