Speaker cable terminations
Started by jimbones, April 29, 2012, 07:32:23 AM
jimbones
What is the preferred speaker cable termination? I have old Monster Cable bananas with spade lugs that you have to use a allen key to tighten. I don't really like them. What is everyone using these days?
WBT bananas. They tighten firmly with a knob that widens the banana to grip the hole twss. A ferrule is crimped to the cable, then the banana tightens to the ferrule with two torx set screws. I like them.
I think most people are using whatever came on their wires for the most part.  Spades or bananas? I use spades.
It's rare that speaker termination makes a difference in SQ that is really noticeable.  Note I said rare... I don't have an issue with monster cables but I always used them without termination.
jimbones
Quote from: Carlman on April 29, 2012, 02:56:20 PM
I am using MIT Shotgun with Monster connectors. these seem interesting:
http://www.electracable.com/tubeconnector.htm
Yeah, those do look pretty cool. I'd like to try those.
Another that appeals to me is the Eichmann Cablepod.
http://www.vhaudio.com/cablepod.html
Expensive, and I read that it is not very strong.
  Jim,
            Connectors add impedance. If you can use no connector just bare wire go for it.
    For me less mass the better. Clean the terminals with Pro Gold be done and save money.
    If you must look at Furutech, WBT or Vampire.
jimbones
I wasn't really clear, I am not concerned about SQ as much as I am about the reliability of the connection. On my current terminations the connections loosen up over time. I don't really like them. It must be a solid connection.
mgalusha
Quote from: richidoo on April 30, 2012, 06:44:35 AM
IME they are not good mechanically. If using spades the plastic that presses the spade into the contact eventually starts crumbling. I kept finding little bits of red and black plastic behind the amps and eventually they failed completely. They are probably OK with bananas.
I have some of the angled WBT banana, they are bullet proof. I also like spades, my speaker cables have spades on one end and WBT on the other.
mike
jimbones
Quote from: mgalusha on May 01, 2012, 08:57:17 AM
mike
Yes, I concur the WBT look to be very good and I will buy some. Thanks
Face
Compare quality copper or silver spades/nanners to junk from Ebay or Monoprice, you may be surprised.
I agree, wire terminations and posts can make a huge difference. Some junk posts are made of white metal, like these, and sound really awful.
DH Labs has some nice pure copper spades that are very inexpensive. They crimp or solder and are goldplated.
http://www.silversonic.com/docs/products/Connectors3.html#Spade
jimbones
No knock offs allowed. I'll pay the price for the better part.
To clarify, I was thinking he was re-terminating monster cables in my first post... so any 'good' connector would do... I hadn't considered using the cheapest junk possible and comparing that to Cardas, WBT, etc.  I was thinking if you re-terminate with DH Labs vs. WBT vs. Cardas, it's not going to be readily apparent in my experience.
Truedat!   Anything >50% copper is in quality territory.
jimbones
Quote from: Carlman on May 03, 2012, 07:24:41 AM
We're on the same wavelength! :thumb:
