Modified SB3
Started by Dougie085, October 04, 2008, 08:49:21 AM
Dougie085
Well I talked to Russ White and Brian Donagan who own TPA and this is what they said.
Quote
Hi Doug-
The LM317 is capable of 1.5A, so you should be fine.  I think Russ was using one to power a Sqeuezebox.
Then this is the email I got moments later from Russ
Quote
Hi Doug,
You have to calculate the Voltage drop and dissipation for R1-R4. With the stock values the max practical output current will be < 1A
To get more you will need to use lower value resistors or simply jumper them with wire. The penalty for this is slightly less noise rejection.
If you are using the digital output from the Squeezebox there is absolutely no good reason not to use the stock power supply.
Cheers!
Russ
So I can use the TPA PSU I just have to change the resistor values to be able to support probably up to 2 amps.
