Crossover upgrading
Started by Carlman, August 28, 2009, 11:37:55 AM
Rick used 'Clarity' caps.. and I'm sure they'll open up more with break-in.. but I don't know how much.  They're of reasonable size.  Steve took some photos of the crossovers.. maybe he'll post them here?
Face
Still lovin' it.  I've done some tube rolling and things just keep getting better.  I just moved my speakers an inch and need to re-measure everything again to get them dead-on.. but I haven't really wanted to change anything yet.. I still want to add subs, though.
Face
Any pics or a description of the modifications?
Mike
I came here to make a quick update and noticed I'd missed your question, Face.. I thought someone shot some at our big comparison/G2G with Stereofool's stock C8 Ltd's.  It's nothing spectacular.. For now just imagine point to point wired caps and inductors, in a big black box.  ;)
Back to the update.. I decided to pull down the tweeter a touch because it's just too harsh/hard for my listening/musical tastes.  I wanted to be sure I was doing it right so I enlisted the help of Richidoo.  The friend that he is, he drove here w/ soldering gun and all sorts of tools and toys.. It was basically minor surgery, just add a resistor where Rick Selah described.. but crossovers just aren't my realm... In any case, Rich pretty much just added them.. and thanks a million
My system 'should be' laid back.. I have a tubed non oversampling DAC, tubed pre with romantic tubes, and McIntosh amp.. But it wasn't.  It did/does a lot right, though.  Now it's actually a little laid back, like it 'should be'. 8)
Many songs that were previously unlistenable now are.. and the detail is still there.  I can listen 'into' the music now.  I get to hear the intent of the music... I can reach out and touch the soul.  It's like the singer, cymbals, and high hats took a half-step back.  Also, it sounds like the bass is a little louder which I like.. since I can't afford subs yet. ;)  I'll continue to get used to these changes over the next month and see how it goes.  I might reduce resistance a little to get back a little bite but maybe not.  I think it sounds pretty much like it should given the electronics in front of the speakers.
Do resistors break in?  Seems like it's sort of changing as I listen.. not sure if that's me or the new thing, though..
Thanks again to Rich!!!!  :thumb:
shep
Resistors do break in, but nothing like the sometimes endless process with caps.
You're more than welcome Carlman!  They sound a little laid back for me, but the edge is polished off nicely, which fits your listening style better. Maybe less singeing the eyebrows now.  :D   I prefer it as it was, dead flat for violin excitement. It's only a smidge and on attitudinal rock it is welcome.
If you want a little more bass, you could pad the mids with the 2 ohm, then pad the tweet with the 4ohm. Then M andT stay as they are now but the bass is relatively louder. You got the parts, might as well try it.
