Biased
Started by richidoo, September 24, 2009, 11:08:14 AM
Quote from: richidoo on March 15, 2010, 10:00:05 AM
Thanks.   Sometimes more brightness is needed, on amps with cheap slow OPT, for instance.
Si senor. A great tone control. either way. I don't mind the bright as long as it is NOT thin. gotta have the meat on the bone.  :thumb:
Listens2tubes
My Dynaco MkIV's have micro adjust bias pots also. They were tempermental with bias setting until I installed new tube sockets (teflon) and GEC KT77 re-issues in them. Now, once warm, they almost never need re-biasing.  :thumb:
I used to bias at 1.56VDC and would know when the bias had climbed to 1.62 when the highs hardened. I now set to 1.25VDC. That said, I did test different bias settings for sound and found only the higher setting to affect performance.
