"Cheapskate" Office System???
Started by StereoNut, September 03, 2010, 11:40:57 AM
Quote from: Carlman on September 03, 2010, 02:01:09 PM
I like the cheap Onkyo 2-channel receivers but they have 0 cool factor... but sound pretty good.. just a thought.
And if the FM section is of any importance to you, Onkyo units nave long been known for good tuner performance....
StereoNut
Quote from: rollo on September 04, 2010, 07:49:00 AM
  Don't rule out NAD or Rotel. Saying that if the speakers are efficient check out Vista, A simple solution is to get powered speakers like Audio Engine and sell the Pre and speakers. These little gems sound great. Several guys in our club bought them. Then you can sell the Cambridge and get a USB DAC and be done at the office. Less space inexpensive enough.
I haven't ruled anything out completely yet.  NAD & Rotel are definite considerations.  I will check out Vista next.  (Thanks for the suggestion.)  It's for a home-office/bedroom set-up, but I don't think I'm ready to go the computer front end route just yet. (BTW - I've heard the Audio Engine speakers and they are gems.)  Right now (although if you give me 10 minutes, I'll change my mind!) I'm kinda leaning towards finding a power amp and keep the Parasound Pre.
FWIW - According to the specs Rich posted, my NHT's aren't very efficient (86db)
Keep sending in suggestions, maybe something will finally make up my mind!  ;-)
SN
In a bedroom system where you won't play it loudly, even 86dB speakers will sound fine with ~50W. It's 6 ohms minimum, so any decent amp will work. I doubt you would go past 10W very often.  That's why that Lux in class A is so tempting.  But it will be very warm. Think of that if you need to stack things.
StereoNut
Black Sand Cable
What about a Creek integrated?
I can hook you up for cheap!  :D
bpape
That's a derivitive of the old Acoustat Trans Nova Twin amplifier but modded for industrial use.  The TNT wasn't a bad sounding amp.  Nothing special but built like a tank.  GREAT bass amp even though it was MOSFET.  Hafler bought out Acoustat and let the speakers die but kept using the amp designs.
http://www.audiocircuit.com/Home-Audio/Acoustat/TNT-200
There was also a TNT120 IIRC.
JLM
Haven't found much info, but Peachtree Audio is introducing a "musicbox" (a mini version of the iDecco) meant for desktops.  Looks interesting as it uses a "baby SABRE" DAC, tube pre-amp, and allows for multiple inputs.  If it has pre-amp outputs (maybe even subwoofer outputs like the iDecco) it could also be the basis for a nice stepping stone for a budding audiophile.
Black Sand Cable
Quote from: JLM on September 08, 2010, 11:55:59 AM
I have some promo material on the Music Box. I tried to attach it here but it wont let me as the file is too big.
For anybody who wants to peek at it, you can get it via the link below.
http://www.megaupload.com/?d=RDGABJXT
evan1
Quote from: Black Sand Cable on September 08, 2010, 12:57:21 PM
What am I looking at or for ?
Just got a catalog in the mail from MusicDirect.
How about this:
Music Hall a25.2 Integrated amp
50 wpc into 8 Ohms (100 into 4)
Line Stage only (no phono)  :(
Stereophile Recommended Component and The Absolute Sound Editor's Choice Award Winner
Regularly $699, now 50% off - $350
http://www.musicdirect.com/product/88057
I've never heard it myself, but it comes with a good pedigree and a 100% Money Back Guarantee.  :thumb:
Black Sand Cable
Quote
It's some online storage that I use from time to time. Just follow the prompts to get the pdf. Don't worry, its safe.  :D
Regg
I've got an ATI AT-1502 you can test-drive if you like...I don't live very far from you.
http://www.wwsp.com/ati/at1502brochure.htm
StereoNut
Thanks, JLM - but I can see that including "office" my subject line has mislead you a bit.  Yes, the system is for a home office, but I am not looking for a computer based audio system.
SN
StereoNut
Quote from: Regg on September 08, 2010, 08:10:17 PM
Hi Regg
Thanks for the offer.  I may take advantage of that somewhere down the line?  Do you know what the pricing on the ATI AT-1502 is?  When I went to the link you posted, it wasn't listed on the price list.  Is the AT-1502 a discontinued model?
SN
