TT advice?
Started by richidoo, March 30, 2007, 10:13:32 AM
biglou
dangerbird is right... the forum description for this section is right. with vinyl there's always another upgrade, you start buying extra copies of favorite LPs, space disappears, need more sleeves, new fluid, another cartridge, more vinyl, more gruv glide, and ahhhhhhh!! i've convinced myself that my vinyl expenses are an investment... LOL
WEEZ
..."my vinyl expenses are an investment"..
Well, if 'ya gots the software, then 'ya gotta' have the hardware... :)
Quote from: Black Sand Cable on July 08, 2007, 10:25:33 AM
Before running out and spending any money on isolation, try hockey pucks! Don't laugh until you try it!
I have a very good customer of mine that is running a JC Verdier and after trying a fair number of isolation options that are out there he ended up running with my tweak of choice.....hockey pucks and has never looked back.  :)
   So I'm not the only one who uses Hockey pucks. Great tweak. Use them under my Linn coupled to a Sound Organization rack which sits on 3 tiers of 75% solid concrete blocks filled with sand. Could not be happier.
Looking for a high output Cart. for my Linn. Use Ittock 2 arm. Any suggestions. MC or MM not sure. Use Micro Benz M2 now. Seems a bit polite no sparkle. Phono stage has 52db of gain.
  thanks
WEEZ
rollo, have you ever tried an AT OC-9?
More sparkle. Maybe too much more. Dunno.
Maybe a slight tail-down adjustment on the Benz will help?
WEEZ
Quote from: WEEZ on August 14, 2007, 03:22:39 PM
WEEZ
weez,
              Thanks I'll give it a try. Have not tried AT OC-9. At this point I have always used MC type cart. My gain is 53db in phono section. Thinking of high powered MC or MM. Actually not sure. Budget is $1500.
         Have been looking at ZYX, Sumiko Blackbird, Clearaudio Virtuoso and Dybavector. I use a Lingo and Ittock 2 arm. The phono stage is a tubed Loesch and Weisner. Help!
WEEZ
rollo,
The OC-9 is a MC with .4mv output; so my guess is you would need a scoosh more gain, and 100 ohm loading. These things sell for about $275, which is a bargain for a MC. (Provided you like the sound)
You could always try a 1.5 mv Wood body Grado. Not advertised as available...but they are.
WEEZ
jrebman
Rollo,
Given your budget, maybe add the Ortofon Kontrapunkt B to your audition list -- assuming it will work with your arm.
-- Jim
Thanks for the help Guys.
dangerbird
not to derail this,,but I just picked up a VPI scout,with the dynavector 20 Xl (low output mc) and I'm using a dynavector p-75 in the enhanced mode; now,,any suggestions on cables from the phomo to the pre--to the pre-amp? Currently using a 1 meter pair of grovers from the phono pre to the preamp,and someignal cable silver from the tt to the phono pre.
Damn, I just read this,,I hope it makes sense--too lazy,I guess to retype :roll:
Makes sense to me! Don't worry this thread is derailed many times over, but is great because it's still going!
Your TT>phono cable looks good to me. They are shielded which is important with super low level signals. I heard Signal's Silver SCs and they were excellent, just a little bass shy. The website blurb about these ICs says awesome bass, so as long as you're happy with them and they're quiet that's all that matters!
I don't have a lot of experience with ICs for line level signals, limited to Anticable copper, DHLAbs, Belden 1505, Grover and JPS. I happily use all Grover S now, but I will get some JPS SC3 when I can swing it, they are about 8x more $.
dangerbird
Thanks Rich,,I noticed that the system lacks a tad of bass,,you confirmed what I suspected,,but I did not know where. I'll experiment with some tt-phono cables,,I thought that I read somewhere that Grover has/had made some short cables for tt-pre,,I'll e-mail him--thanks again :D
WEEZ
dangerbird,
Maybe you're aware that VPI offers phono cable made from the same wire as inside the tonearm? Might make sense to start there? Just a thought...
WEEZ
Quote from: WEEZ on September 08, 2007, 06:28:27 AM
dangerbird,
WEEZ
A good thought at that. VPI has got a winner with this cable for VPI TT. Synergy baby. Stop the search and go for it. You get a thirty day MBG from Music Direct or Acoustic Sounds. You can't lose here. Its a no brainer.
dangerbird
dangerbird,
WEEZ
Nope,, did not know that,, I'm dumb and slow,, :shock: I'll check it out,,thanks for the help- :D--george
