Whatever you send I would be happy to use to host an event at my place. My speakers are a bit demanding on power, I would say minimum 100wpc for a ss amp, not sure about tube power.
If you're sending speakers, I use a McIntosh MC402.
I would keep the gear swapping to a minimum. Most folks know what my room/system sounds like so there would be a good comparison to my normal setup.
If that sounds good, put me on the list of whatever you want to send.
