My new PC build
Started by jsaliga, May 24, 2011, 04:57:18 PM
That actually seems like it'd be a really good video production machine... I use Adobe Premiere CS5 64-bit and it makes a huge difference when you have good memory and processor.  I recently bought a new machine that could keep up and not crash.. requiring a good graphics card, 8G of RAM, 2.8G AMD, etc.. Had I seen your 'tank' of a PC, I might have gone that route instead... It looks really well put-together and well organized.  Congrats.
This is turning into something of an adventure Carl.  And I don't necessarily mean that in a bad way.  Overclocking to even 4GHz on this setup isn't really doable.  The machine is nice and stable, even at 4.2GHz or 4.5GHz.  The problem is heat.  I thought that the Cooler Master V10 would be a good alternative to water cooling that would get me to 4GHz but I was wrong.  The CPU goes on a steady heat ramp and after about 10 minutes under 100% load on all six cores the temps get to 85C.
Why am I determined to overclock?  Because without it I am leaving a lot of potential performance on the table.  Stability is not the issue and the voltage bumps I am using are not particularly agressive.  At first I thought that I may have mounted the Cooler Master heat sink incorrectly or it wasn't making good contact with the processor, so I took the machine apart and reassembled it and am getting the same results.
So, as much as I was hoping to avoid water cooling it seems to be the only real choice with these hexacores if you want to squeeze the most performance out of them.  I could bump the overclock down to about 3.6GHz and keep the temperatures at ~ 65C.  But with water cooling I should be able to get to 4.5GHz.  While this might sound crazy I am going to ditch the Thermaltake Armor+ case (a move that Gene will probably applaud) and replace it with a Silverstone TJ07 Black case.  The Armor+ will support a water cooling rig but not with the radiator on the inside of the case, and I really don't want a big 120x3 radiator hanging off the back of my machine.  The SilverStone can accomodate a radiator on the inside of the case (in fact it can take one three fan and one two fan radiator, so I could go with a dual loop configuation if I wanted to.
I also applaud the Silverstone case, 2 of my builds are in them, and my media server almost was but I got a great deal on an Antec P-180 case instead.
Six cores @ 4.5Ghz?  :shock:
You'd better make sure that the generators for your emergency cooling system are not in the basement where they could get flooded by a tsunami.  :lol:
I've seen a few people on Overclockers.com run their quad cores at up to 5GHz.
Quote from: etcarroll on May 31, 2011, 07:06:39 PM
I also applaud the Silverstone case.
Glad you approve.  ;)
Seriously, I decided on the SilverStone purely based on function.  It's a nice looking case, to be sure, but it won out because of its suitability to host a completely integrated water cooling loop.  It also gives me some flexibility.  While I am not planning on water cooling the graphics cards, I can add a second loop if I want to.  I also looked at custom cases that are handmade and designed from the ground up for water cooling.  They get very large, like double wide full tower ATX cases -- no thanks.
If the SilverStone didn't offer the features that I needed then I very likely would have ended up buying a Cooler Master HAF X.  The only other case that qualifies is the Corsair Obsidian 800D, but I ruled it out due to numerous reviews citing issues with airflow.  Even though I am going to water cool the processor, I still need to move air to those Nvidia GPUs and the MB.
I always believed that, for PCs at least, function needs to trump looks. I'm just pleased the Silverstone cases, and the Antec, happened to look good while providing the function I wanted.  ;)
Quote from: jsaliga on June 01, 2011, 04:38:46 AM
You bet. It wan't too long ago that most computers had less memory and processing horsepower than those GPUs alone.  :roll:
Well...I totally chickened out on the water cooling.
I recently read about the misadventures of a water cooling noob who ruined several hundred dollars in hardware because of a radiator problem that happened after a supposedly successful leak test.  That was enough for me.
But I haven't given up my desire to overclock.  A friend recommended the Noctua NHD-14 CPU cooler.  It's another massive air cooler.  I told him about the poor overclock results I was getting with the Cooler Master V10 and he said that if I tried the Noctua and couldn't get my processor to at least 4GHz with temps under 75C @ 100% load that he would buy it from me for cost.  So I am going to give it a try.
I have also decided to add a third GTX 570 for 3-Way SLI and will replace my 32" HDTV that I am using as a monitor with 3 Dell 24" Ultra resolution 1920 x 1200 monitors for surround gaming.  The Silverstone case was still a good buy because it has better ventillation than the Thermaltake, and with three GPUs it is going to need the extra airflow.
I nixed the Dell monitors and instead decided to go with three Acer G Series 24" 120Hz monitors so I could use Nvidia 3D Vision.  It's all on order and should be here on Friday.
Geez, I've created a monster.  8)
What are you gonna use this monster for?
World domination.  :rofl:
Seriously, the three monitors will service two purposes.  It will help to make me a bit more productive at work (I work mostly from my home office).  But the more obvious purpose is for Nvidia Surround Gaming.
http://www.nvidia.com/object/3d-vision-surround-technology.html
I'm not the hardcore gamer I used to be but I still enjoy PC gaming when I can find the time.
Awesome!!  And the occasional CD rip at 50x...  ;)
Quote from: jsaliga on June 15, 2011, 04:50:33 AM
We'll have to start calling you "The Baron"  :rofl:
