Getting My Feet Wet in VINYL
Started by evan1, September 16, 2011, 02:11:57 PM
topround
My SME 3009 had  a similiar arrangement for anti skate and it was nearly impossible to move that damn string to the next groove. :duh
Great sounding arm though, sold it , and moved on to a better easier to setup arm
Evan it sounds good from my computer speakers
evan1
I should of asked Jim first but I found a guy in Canada who has the JJ pre and he sent me a PDF file of the owners manual (all 3 pages ) so I can set the dip switches on back for the phono stage. Now she is singing sweet. No noise , nice warmth in the mids, bass reaches deep and nice shimmering cymbals. I originally was using it the way Jim gave it to me with all dip swithches off which is = to 47pf /47 kohms. I have dip switch 8 on which equates to 267pf/47 kohms and it sounds awesome.
evan1
I have an isolation question. Thinking about doing a sandbox based upon the design found on the web. I'm sure you all have seen it
http://www.tnt-audio.com/clinica/sandblaster_e.html
Is this better than doing a platform like the Ginko with rubber balls ? And do these eliminate airborne vibrations ?
I don't have any isolation problems that I'm aware of and just want to see what it will do for my sound.
  The sandbox method is very affective. Built my own and no going back. The sandbox is mounted on Target speaker stands. Screwed to speaker stand and spiked to floor. If you cannot use or perfer not using the speaker stands either cones to a wood surface below or Mapleshade Isoblocks will do the trick. Very affective.
  Some like using tennis balls to fill the box in lieu of sand. Have fun trying.
SMA
topround
Evan,
I can sell you a Bright star sand box for $50, in beautiful wrinkle black
evan1
Quote from: topround on November 20, 2011, 08:42:09 AM
Evan,
What are the dimensions ?
topround
The platform it sits on is 13.5 by 17.5, overall add an inch or so for total size..
evan1
Quote from: topround on November 21, 2011, 02:12:54 AM
Bring it to emils so I can check it out
Sand boxes are great for adding mass to a turntable, or to an overall shelf/rack, and that helps with isolation, to a degree. But it will not stop everything. In fact, the mass on a sandbox actually couples to the stand and some low thumping vibrations (i.e. knucke raps on the stand itself) will still be transmitted through the turntable. The Ginko solution will in fact get rid of these.
Coupling a Ginko type solution to a sandbox will get you 98% of the way there. Here's my stand - integrated sandbox for each shelf w 50 lbs of sand in each, and a DIY Ginko under the turntable using 12 squash balls under a 1" maple butcher block sitting on top of the sandbox shelf.
evan1
How about if I add heavier feet to my table?
Putz
I just ordered new feet for my VPI Aries from [urlhttp://edensoundaudio.com/pricelist.html][/url]
Got the Terrastone ones. Should have them in a couple of days. Money back if i don't like em.
Also using a 2" thick Maple block (found a John Boos cutting board on ebay for a great price).
Whole thing is sitting on a Target wall shelf about 5' off the floor. If i host a Rave, hope to have Lonewolf pose next to it.
  Bob good point. I used Zorbex to decouple the box from the stand. first attempt was screwing a Maple plinth to the stand with Isoblocks supporting the sand box.
 Nick from Arcicci gave me these Zorbex isolation pads to try. So far no complaints. The homemade Ginko solution sounds good as well.
SMA
