All this talk about VINYL gave me NERVOSA Big Time!!!!!!
Started by Triode Pete, September 17, 2011, 09:06:59 AM
Hey Pete, have you thought of trying a Shelter cart. with the new tt?
I've been going back and forth between a Shelter 501MkII and DV 20x2-L, both have strong points.
What I'd like would be a cart with the DV mids and the Shelter top end and air.
Triode Pete
Quote from: tmazz on September 19, 2011, 12:35:36 PM
Quote from: Carlman on September 19, 2011, 12:16:25 PM
Well, you guys got me all itchy about my vinyl rig... I had every intention of selling it.  It has had a loose pivot on the arm for a long time... and I fashioned a tool to tighten it... problem solved!  Then I found the VTA adjustments and decided hey.. I'll play around with this thing and see how it sounds... So, I fired up the ol' phono pre and started adjusting.
Whoa.    :shock: I did not have VTA setup properly.  There is thunderous bass along with mid and high clarity I have not heard before out of my vinyl rig.
There is a breathing 'alive' quality that is just beautiful.  I quickly compared to the same on digital which sounded diminutive by comparison.  Digital was overall cleaner, much quieter background and the tonal balance was just different.. it had a 'leaned back' presentation where the bass was big and low and the highs were a little recessed.  It was similar to the difference between Rich's DAC and my own... so, my DAC is now getting bested by my vinyl rig.
I was using Sufjan Stevens 'Illinoise' album in these comparison.  Wonderful pressing, btw.  This album was masterfully crafted for vinyl playback.
There is still some noise I don't like with vinyl but the music comes through in a way that it's easy to ignore.
So now what?  I plan to compare my current table to an older table I have so I can possibly sell it.  Or just keep it.  Or keep 'messing' with it.. ARGH!  Nervosa indeed.  :lol:
SCORE!!! We just hooked in another one.  :thumb:
BTW, Grant just left my home after I played 3 cuts from 3 different LP's on my new WT Reference... some of his words, "Presence, PRAT, dead silence between notes, unbelievable decay"... he's running to get his SOTA table set-up better now...
Chalk up another one to the Vinyl Frenzy!!! Ha-ha!!!
Quote from: evan1 on September 19, 2011, 12:59:48 PM
Carl what tables do you have ?
I have a Pro-Ject RM6 w/ Dynavector 10x5 and a Sony direct drive w/ Adcom cart from the late 80's. ('Allenzachary' hooked me up with the Sony/Adcom combo, thank you!)  I'm using an Eastern Electric phono preamp.
For the odd occasion where I listen to vinyl, I would be fine with a lesser rig... and the Sony is actually not bad at all.  I would put it against something like the Technics 1200 any day... and have it win.  It is also easier to use, full auto return and such.. But I doubt it would compare well to the RM6...
Triode Pete
Quote from: etcarroll on September 19, 2011, 02:31:26 PM
Gene - I had a Shelter 501 before anyone heard of a Shelter cartridge but unfortunately it didn't synergize the best with my phono stage which really likes higher output MC's & MM cartridges...
Pete
