Minimizing Tube Rush / Hissing
Started by shadowlight, November 23, 2011, 03:54:03 PM
shadowlight
Thanks everyone for all the helpful suggestions.  Will try them all over the holiday weekend.  Right now it is very distracting with the hiss.
shadowlight
Thanks changing the tubes got rid of the rush/hiss but now I am hearing a slight hum which does not change when I increase the volume.  Need to trace it down  :duh
Quote from: shadowlight on November 26, 2011, 04:03:56 PM
   Sounds like the ol transfomer Hum Drum. Good luck with that one.
    First check your wire management, meaning to not let them touch each other. Keep them at least 6" apart. Next distance between components, keeping the transformers from being to close to each other.
    Use only one outlet to avoid ground loops. If your CDP has a ground lift switch try it. Good luck
SMA
shadowlight
Quote from: rollo on November 27, 2011, 08:02:16 AM
SMA
Yep, I am going to disconnect everything and work my way in isolating the hum.  Never had any ground loop hum before so that should help.
Even with the slight hum I am enjoying the sound from the GR-Research V2, Vincent amp, Bella L/P and Logitech Touch.
shadowlight
Found the culprit.  I get hum when the receiver is connected to the preamp.  If I go directly from the receiver to amp no hum.  It seems that I am creating a ground loop between the preamp and receiver.  The receiver has a ground post.  Do I just run a regular electrical cable from that grounding post to a common ground or do I need specific size/gauge/solid core electrical wire between the two?
Thanks for all the help so far  :thumb:
Deepak, by any chance do you have cable TV connected to the receiver? Cable is ground is notoriously noisy. If you do have cableTV hum or other sat/FM antenna ground loop issues, try this great little isolation tranny from jensen transformers: Model VRD-1FF
http://www.jensentransformers.com/iso_vid.html
Also make sure the cable is earthed prior to this isolator. I use these lightning protector/ground blocks for grounding my incoming coax sources:
Altelicon AL-FFFF
http://www.l-com.com/item.aspx?id=20928
Glad to hear that the tube rush is all better, and the hum is not in your stereo system. Now it's time to kick back with some tunes, eh?
satfrat
Quote from: shadowlight on November 27, 2011, 11:52:05 AM
Hi. I might recommend an EVS Ground Enhancer on that ground terminal Deepak. Allthough I use many GE's in my system, I personally use an Acoustic Revive Ground Conditioner on my processor but a $25 Ground Enhancer surely beats my $450 unit.  :rofl:
http://www.tweakaudio.com/EVS-2/EVS_Ground_Enhancers.html
Cheers,
Robin
shadowlight
I plugged in the cable tv into the APC S15 unit and from there to cable box and the hum is gone.  I am in business now  aa
shadowlight
Quote from: richidoo on November 27, 2011, 04:12:50 PM
Awesome!
Thanks for all the suggestions, which helped identify the culprit.  Never had any issues when I had Verizon Fios or Directv.  As soon as I get Comcast I get hum.  I should call them and bitch at them  :duh
TooManyToys
Now I know who to ask about TV service.    Maybe I'll wait until you get Dish.  :)
shadowlight
Quote from: TooManyToys on November 28, 2011, 07:00:29 PM
No chance.  As soon as my contract with Comcast is up I am going back to Verizon Fios.
