Pics of the room after some changes
Started by musicfile, December 04, 2011, 01:11:12 PM
musicfile
Here's a few pics of the room
I'm still not sure about speaker postioning will play with this
To recap the system used to be on the long wall I Reoriented the system 90 degrees
I'm hearing more indirect sound then before the Lf is much bettter but would like to hear a bit more highs and depth
My listening chair not pictured goes underneath the stair case
Any comments or opinions appreciated
evan1
First, I would love to hear the speakers. Forget the name though. Any pics of when they were on the long wall ? I would think in that nook you would be getting alot of reflected sound. How far away is that staircase ? I don't know if its a good idea to be seated under there. Post a pic of the left side of the room.
Beautiful system!! What kind of speakers are they?
I am afraid of that alcove behind the speakers. It will act like a big parabolic horn shooting back at you. But that might be just the EQ that you need for perfection.
You are making the best of a difficult room. You will learn so much about acoustics by fixing that room. I'm really impressed by your efforts and commitment!
Check out REW software for measuring FR sweep and echo duration. It will either help a lot with acoustics or put you in the funny farm once and for all!  :thumb:
musicfile
Here's a pic of the old speaker postioning
I am getting a bit of echo but the sound is quite good
The soundstaging has improved and i'm hearing more of the recordings
The speakers are the Ridge Street Sason's
Thanks for looking and providing input
musicfile
Quote from: evan1 on December 04, 2011, 01:56:47 PM
Hi Evan
If you're ever in Canada Toronto give me a shout
I am getting some reflected sound but so far it's not so much of a bad thing  :thumb:
The staircase wall is 12 feet away from the front wall
I've tried sitting in front of the wall and directly underneath it the sound is different and depending on the music you are listening to it you may prefer either one
I will try to post a pic of the left side
Did you ever consider a non symmetric layout, where your listening seat is kinda in the center of the speakers in this pic:
and the speakers are over near the red couch and brown chair. The advantage to that might be getting more space around the speakers and you further away from them. The disadvantage would be wall echos coming at different times, and different EQ flavors from the different space shapes behind the speakers. Your treatments can reduce some of that flavoring. Is there enough room to twist diagonally like that?
Judging by your attention to detail I'm sure you already considered every possibility, but sometimes angled setup is not unintuitive. But sometimes it can work.
musicfile
Quote from: richidoo on December 04, 2011, 03:53:38 PM
Hi Rich
I did consider this the issue here is my ceiling is very low and I don't think this would work as well as having the speakers on the short wall
I want to experiment a bit with difffusion and see if this improves things
btw where do I get REW program you mentioned
I also wanted to do some ECT Tests
Here's the REW link
http://www.hometheatershack.com/roomeq/
It is very powerful, but pretty easy to use. What are ECT tests?
Maybe just twisting it by 10 degrees, move the right speaker out into the room 6 inches, and move your chair to the left a couple feet. That will get your right ear away from the right wall, if after a while you start to "feel" it there.
Another thing I just noticed, is the two small parallel facing walls just behind the speakers. They will make a slap echo that will ring very long. They are a small surface, but they are right close to the speakers so the signal will be strong. And the nook may amplify it toward you. If your floor tiles are 1 foot, then those walls are 9.5' apart and the echo frequency will be 1425Hz, upper midrange, ears are very sensitive to that. But it's high enough freq that 1" panel or some soft art will kill it.  By the looks of your neat decorated room, there is likely a wife lurking, she can find some cool tapestry wall arts for you!
musicfile
#8
ETC stands for energy time curve
this is a great article to read
Acoustic Measurement Standards for Stereo Listening Room
Written by Jeff Hedback and Nyal Mellor
I need to digest what you wrote further and try to implement where possible
Thanks again Rich
Pat
Got it in my "Check it out" favorite folder. ;)
musicfile
Well after a few weeks of playing with the system
I moved the speakers approx 1 foot forward removed the hanging absorber on the left side and placed it in the Left corner next to the door
By making these two changes the speakers have opened up the soundstaging is WIDER. Overall depth has increased
Imaging is has taken a small step backwards but so far I really like what i'm hearing
I thought that by removing the speakers from the cove the sound would deteoriate
Im really scratching my head now what sounds good on paper vs listening  :o
Quote from: musicfile on December 18, 2011, 07:02:30 AM
  Good news , however you made the quote of the century. " What sounds good on paper vs listening".
  BRILLANT !!!!
musicfile
#14
It goes to show you proof is not always in the makeup of the pudding.  Execution is Key  :thumb:
Trust your ears my friends
