Turntable Wall Mount
Started by StereoNut, February 11, 2012, 08:41:23 PM
StereoNut
So... since I am trying to figure out how to accomplish this task (working with a 24" span between studs) and yet make it as least offensive visually (to remain married!)  I will now complicate it further.  :shock:
I have attached a picture of a Lovan audio rack like I have. (See below.)  Since I have been staring at my wall in my listening room trying to think of a way around my TT wall mount problem, I've been thinking about "wire management" too.  I figure if I'm going to drive myself nuts, I may as well do it "all the way".  :rofl:
Do any of you have any ideas that will hide my I/C's, Power Cords, etc... behind an open rack like I have that I can somehow incorporate into my wall mount solution?  :roll:
Suggestions...???
Thanks!
Make a full height hollow box as your stud widener, 6" deep. Veneer it or faux paint it to match.
StereoNut
Quote from: richidoo on February 21, 2012, 12:03:59 PM
Cable cloaking device:
Aaaaaaaahhhhh!!!!!!  You just made my whole day, Rich!   :rofl: :rofl: :rofl:
Quote from: richidoo on February 21, 2012, 12:18:47 PM
A great idea then you can a light behind for a soft glow to come out the top and bottom (with the wifes approval of course) :rofl: :rofl: :rofl:
toobluvr
Boy oh boy, what a hassle!!  Change your table, as per my comparo and suggestion here (reply #24):
http://www.audionervosa.com/index.php?topic=3426.msg43770#msg43770
Spare your walls the butchering.  Spare your marriage.  Spare yourself the work and aggravation.  But most importantly, get better sound, and a fatter bank account.  And no more worries about footfalls.  For a solid summer my street was completely ripped up for new sewer/water lines.  The house was shaking like it was gonna fall down.  Played my Rock III thru everything...didn't skip a beat.
A Rock III table will run about 500-600 used.  Add a decent Rega or Michell Techno-arm and you are done for around 1000. (I use Kuzma Stogi Ref on mine)
A used Kuzma Stabi "s" / Stogi "s" setup will cost 1000-1400 and will also beat the Linn.
Not just talking crap here, I have owned all three setups.
I see you are on LI.  I am too.  Come by for a listen.  Feel free to bring your Linn for direct comparo, if you like.
Good luck whatever you do!    :thumb:
TT2: OL Aurora/OL Silver Mk3A
  Your killing me BRILLIANT !!!! Is it Cryo treated ?
toobluvr, thanks for mentioning The Rock again, it looks pretty cool.
Does it have a suspension that isolates from vibration? I didn't see that mentioned in the website for the V7, but I didn't study it.
http://www.townshendaudio.com/turntables/the-rock-7
edit: http://app.audiogon.com/listings/townshend-rock-7-with-dust-cover--2
toobluvr
#38
I have a Rock III, several generations older than the 7.
It does not have a sprung suspension.  It has a built in air bladder (just like the Townshend Seismic Sink) and a silicon dampening trough at the cartridge end.  The 7 only has the latter.
a review:
http://www.regonaudio.com/RockMarkIII.html
a discussion on the various Rock iterations:
http://www.hifiwigwam.com/showthread.php?44543-Townshend-Rock-3
So to avoid a wall mount, I would need a Rock 3? Rock 7 would still need a wall mount? Thanks john
toobluvr
Quote from: richidoo on February 22, 2012, 05:25:11 AM
No experience with the 7 so I can't comment on it, but wall mount not needed with the 3.
Triode Pete
Quote from: toobluvr on February 21, 2012, 03:36:13 PM
John's table & system sounds very nice!
Be a Linn "separatist", just like Mr. Rollo!
My $0.02
Pete
StereoNut
Pete and John
I appreciate the thoughts here, but going to a new (different) turntable is not as simple as you make it sound.  Besides taking into consideration what's involved with finding a reasonably priced used Townshend Rock III, tonearm & cartridge combo. as a replacement.  I'd also have to simultaneously find a buyer for my LP12 to fund that purchase and do it all without the benefit of having a safe and secure Audiogon site to buy & sell from.
Believe me, I can't imagine anyone that wouldn't jump at the chance to have better sound and put some extra cash in their pocket.  I just don't know if I'm willing to wait for that whole process to come full circle right now.
If (?) I can somehow solve my wall mount crisis now, it doesn't mean I can't explore "swapping" turntables at a later date.  I'm sure the Townshend Rock III or any other new/used turntable won't mind being on that wall bracket when (if?) that time ever comes.
I will keep you all posted as the saga continues...
#44
  Bill years ago when designing a interior of an apt we were asked to come up with a solution for racks.
  We used small Roman style columns topped with wood. Attractive and functional. Spiked the bases and looked great.
  If it were me I would consider selling the wall mount. Use a column with a sand box atop. The inside of the columns are hollow. A great place for wire management. If you like you can fill the columns  with sandblasting material. [ Steel ]. Better than sand.
 In the end three or four columns [ spaced apart ] with either individual wood tops or one large top with columns below. Looks great works sonically as the gear is spaced to reduce magnetic field interference, so a nice wood [ Wifey picks out ] and finish the columns any which wat you desire oh my !!
   BTW the footfall issue should go away as well.
