Another DIY Record Cleaner
Started by eleazar, November 04, 2012, 10:16:21 AM
What brand of power cord would be best :rofl: :rofl:
shadowlight
This guy thinks so....
http://www.polkaudio.com/forums/showthread.php?87672-Improvements-To-The-VPI-HW-16.5-Record-Cleaning-Machine
He compared 3 power cords and measured for machine noise. He also tried power conditioner.
Oh, and rollo will like this, he uses Hifituning fuse in it!
I can't even imagine how clean his records must be.
Quote from: richidoo on November 08, 2012, 03:34:41 PM
That's a little over the top  :rofl:
Thanks....Rich
sleepyguy24
Quote from: pumpkinman on November 08, 2012, 03:40:06 PM
It's already to be powered up :thumb:
Man this whole project is awesome. I wish I had these DIY skills.
One other thing though. That stock outlet will not due. It requires at least a Porter Port Hubbell based outlet to get the best power to your cleaner.  :rofl:  :rofl:
shadowlight
needs to be connected to a regenerated power with dedicated 20amp circuit.  is that mini shopvac quite enough if not it needs to be modified before it is ready  :rofl:
sorry could not resist  :-P
Quote from: sleepyguy24 on November 09, 2012, 07:03:46 AM
This is not as hard as you might think. In the end it should cost $70 or less. Jump in with both feet and give it a try you just might surprise yourself.
Did you try it yet Bill? Video? and don't edit out the swearing. ;)
Quote from: richidoo on November 09, 2012, 06:27:07 PM
Yes I did Rich with a beat up LP to see how it sucked water off.
It did just fine. I need to put velvet on the wand and make some sort of weight to hold the LP down.
Now can you help the technically challenged how do I do a video ?? I'll ask my daughter see's pretty good with that kinda stuff.
djdube525
Quote from: pumpkinman on November 10, 2012, 05:05:32 AM
how do I do a video
As in where to store it? You can create your own channel/account on youtube, post it there and then put a link here...
Is that what you were asking?
Dave
