All Plugs and IECs are NOT Equal.
Started by rollo, February 24, 2014, 08:00:11 AM
dflee
Relating to this subject, can ya'll recommend an IEC female connection? I'm hoping to have on installed in my Accuphase C11 pre-amp. Presently it is hard wired.
Don
Triode Pete
#16
Quote from: dflee on March 04, 2014, 08:45:33 AM
Don
Hey Don,
Furutech Gold... I have one in stock if you want it...
Pete
Technically it's a male...  The metal conductors stick out, even though they are down inside the plastic housing. Same with XLRs.
This is what I use for most of my projects. I like that it has a 5x20mm fuse built in, solder tabs with big holes, screw mount, and it can be mounted in the panel from the front or rear depending on how clean I cut the hole.
http://www.mouser.com/Search/ProductDetail.aspx?R=6200.2300virtualkey69300000virtualkey693-6200.2300
I'm sure Furutech, et. al. have fancier versions available.
