True 75 ohm digital cable
Started by jimbones, June 16, 2014, 10:50:17 AM
DaveC
Also, a good digital cable will use silver or silver plated conductors, the surface condition of the wire is very important (hence the plating being common) as the signal is high enough frequency that it will stay near the surface of the conductor (skin effect)
Impedance is the sqrt of L^2 + C^2 + R^2, R is usually small and L and C depend on physical construction.
As far as subjective SQ, a cable that is very accurate for analog signals generally sounds better for digital as well...
    BNC to BNC with shielding a quality conductor. some DAC and CD designers use a pulse transformer after the digital input to ensure a true 75 Ohm signal.
