Static Issue
Started by ejk, February 18, 2016, 02:15:13 PM
shadowlight
#15
Any recommendation on which deoxit to get?  There are lots of options on Amazon, I need to clean the Dodd Preamp.
TIA
Use plain DeOxit D5S6 for everything. I usually use CRC "QD Contact Cleaner," it's cheaper.
Use Caig "Gold" only on gold plated connectors, if you want to get fancy.
Don't use "Gold" on potentiometers or faders. It leaves a coating which messes up the plastic elements. Caig "Fader lube" might be beneficial on plastic elements, I've not used it.
shadowlight
Thx Rich.  Will order some next time I put the order in with Amazon.
Quote from: dflee on October 01, 2016, 06:10:13 AM
Must of been the short tingling sprays that did it.
  Chilling just chilling.
