PI Audio BlunderBUSS
Started by HAL, April 11, 2016, 07:25:25 PM
HAL
Pete's TWL HAL1 AC power cable arrived today.
Will be trying it with the UberBUSS soon to get impressions.  Have a two channel moded ChipAmp setup to give it a listen.
HAL
Liked the first listen to the TWL AC cable.  Now to put some time on it and see the rest of the story.
HAL
Well the first batch of 8 TWL power cords is going on order to go with the first one I have.  This will be enough to get the first part of The Megaliths speakers running with the 16 amp channels.
HAL
Been working very well!   :thumb:
HAL
Next batch of 8 TWL HAL-1 AC cables arrives next week.
Waiting on shipping confirmation on the BlunderBUSS.
Hope Dave's back is doing better.
HAL
The BlunderBUSS has arrived!  This is going to work out great powering The Megaliths speakers.
Twenty Class AB amp's and two Rythmik HX800 servo amps get connected with the TWL HAL AC power cables.
All the amp channels are tested.  Now to get things connected for trials.
The dspMusik RevD 8 channel digital crossover is here and will be connected to it as well.  Will be experimenting with the DigiBUSS with it or with the UberBUSS to power the MS-3 Music Server and data library.
Ribbon tweeter's and installation material have arrived as well, so off to getting it all installed and setup.
Quote from: HAL on October 15, 2016, 12:38:34 PM
Pleased to be part of the madness, my friend.  It is a beast!
Now we know why Dave has been so busy. Blunder Buss looks blunderfull. :rofl:
dflee
Can also see how his back went out.
What's that big boy weigh?
HAL
Did not weight it before putting it in the room.
sleepyguy24
DAMN!!! I lost track of this thread. 24 outlets!! I think that beast should be called THUNDERBuss. Some things though. With all those outlets shouldn't there be 2 IEC Inlets for all that power? That or should there be a 20 amp IEC inlet rather than 15 amp?
HAL
Average idle power for the 20 Class AB and 2 Class D servo amps are pretty low.  Peak power can be high, but doubt I will ever use that much in my room.
Was using my UberBUSS and extension strips with it, but now I needed more outlets for the full 22 amp channels which are now completed.
Last part that gets plugged in is the dspMusik digital crossover that is located near the speakers and goes into the Blunderbuss.
The UberBUSS and DigiBUSS now run the MS-3 Music Server PC and display.
HAL
The BlunderBUSS running the 20 amp modules and two servo amps with the TWL AC cables to the amp modules.
To the right rear of the picture.
