Oyaide? Is it really a better material for IEC's and Plugs?
Started by rollo, September 05, 2007, 06:36:53 AM
Quote from: ger1823 on September 12, 2007, 10:12:16 AM
Are you guys kidding?  Oyaide IECs mop the floor with almost all of the rest.  Furutech's are very good; Oyaide's are better.  If you can't hear the difference between Oyaide and Hubbell plugs -- more power to you!
Cheers and happy listening.
Gerry
  Seems like they are worth a try. Thanks for the input.
