Free 3 Month Tidal HiFi Trial
Started by djdube525, September 04, 2017, 01:13:49 PM
Thanks Dave!
I've been thinking about trying Tidal. Might just give it a whirl.
Keep in mind  that if you have a Tidal HiFi subscription and listen via the Tidal App on your computer the app will software decode the Tidal Masters MQA files, so you can get a chance to check out the SQ of Tidal's CD resolution streaming and the sound of MQA all at no cost to you.
djdube525
FWIW... the deal is still valid. I just took the plunge. All I need to do is download Roon and give that a test run to see if I want to get sucked in...
This is good timing as I wanted an easy way to test headphones from my iPhone come RMAF/Canjam in October. I'm in paralysis/analysis stage for some work headphones (closed... I'm down to 4 contenders), and decided to wait until I could test drive on my own and see what I liked the most... comparing phone to whatever amped sources exist... at least that's the theory anyway.
djdube525
Quote from: tmazz on September 04, 2017, 09:41:27 PM
Stupid Q... Are all Masters albums MQA enabled? Is there anything one has to set up in the desktop app settings, or just pick one of the Master Albums and go from there?
Quote from: djdube525 on September 06, 2017, 02:01:58 PM
"Masters" is the name that Tidal has given their MQA encoded files, so yes, all of the music marked as Maters is MQA encoded.
There are no specific settings that need to be changed. Just point and click on a Masters file and you will be playing MQA. Interesting thought that hadn't come to mind until now, the app will decode MQA to analog, but I wonder what it does if you are using a USB digital out to a DAC. My Bluesound Node outputs a standard 24/96 file to the DAC when it software decodes an MQA file. I wonder if the App does the same. Unfortunately I run to yhe DAC via the node and not staight out of the computer, so I have no way to find out.
Signed up!  I am Beyonce's bitch now!
