Gary’s DIY and Tweaks
Started by gander, January 11, 2018, 12:34:41 PM
Just a quick question for some of you tube guys:
Do tube amps in standby mode  put out half the heat or is it even higher? I basically listen at night only and I usually don't turn off the AC, so Im wondering if generated heat would be an issue fir me at all. (yes, I do turn off the fridge now)
#106
Quote from: Nick B on May 09, 2018, 05:35:10 PM
Nick, generally standby keeps the tube heaters warm and in rare incidences provides a greatly reduced B+ voltage.  Heat production is much less than 50%.
Quote from: P.I. on May 09, 2018, 06:26:25 PM
Thanks, Dave. Good to know as I'm testing the waters for an amp or integrated.
   Gary ??? Where art thou Gary ??
Quote from: rollo on August 29, 2018, 07:11:06 AM
Gary is probably too busy making more cables in his secret lab 👨‍🔬
gander
Quote from: Nick B on August 29, 2018, 07:14:20 AM
Yes, Gary is in his bat cave creating new secret wires.  Nick was in my secret wire lab recently for a good listen. And then we went to a new audio store opening up and that was a great experience also.  I recently got inspired to use bare wire with graphene to mostly reduce and/or eliminate micro-arcing, with air dielectric and I'm getting extremely low capacitance and my best results ever.
And Nick, since you were here I have tried a new version of interconnects and I think the sound is even better.  And that result is only with one digital interconnect, and I haven't put the new design into the analog interconnects yet.  I am receiving parts today and that probably could happen today or tomorrow. I will keep you all posted.
Gary
Oppo 103, SSD drive
Audio Note 2.1B DAC
Tortuga LDR passive pre
DIY speakers w/8" Rullit field coil FR drivers
gander
#111
Quote from: gander on August 29, 2018, 07:37:52 AM
BTW, this is all Charles' fault. He got me looking into very low capacitance wires and my brain got to work. The ICs I'm making now have about 26 pF (picofarads) total capacitance (not just 26 pF per foot), and my power cords have about 60 pF capacitance in a 6-foot length (50 pF per 4-foot length) - lower is better.  Combining that with graphene conductive liquid this is pretty cool.
Gary
And BTW, Nick brought his 1200AS amp and his UberBUSS and they definitely added some nice qualities to the sound, but with the new wire design I'm working on now I would have to hear them in my system again. hee hee
Gary
Oppo 103, SSD drive
Audio Note 2.1B DAC
Gary
Yep, graphene is revelatory when it comes to cabling, especially low level cables.  My trials with speaker cabling are coming along, but it is line level that really shows the schnitz!
Fun, ain't it?   :thumb:
gander
#113
Quote from: P.I. on August 29, 2018, 11:52:43 AM
Gary
My first endeavor into whole-length graphene-treated wire is in my new power cords, which are really stellar.  I use 10-gauge and 8-gauge wire for that.  And I just made a digital IC with the same wire architecture and the sound suddenly opened up and evened-out very nicely, with lots of audiophile goodness; richer sound, nice midrange, more upper range, detail with a little less edge, etc. People don't realize that a "digital" coax cable actually carries an analog signal, so it is not just "bits", and so it isn't unexpected to get better sound with a better digital cable. I am graphene-treating speaker wires and will be building them and making analog ICs next.  Previously, unfortunately because of the price, I had been using pure silver wire most recently, which sounds great but is expensive and leaves a tiny bit of an edge on the sound - these are copper.
Gary
Oppo 103, SSD drive
Audio Note 2.1B DAC
Gary good to see you posting again. Try a 37.5 OHM digital instead of 75 Ohm you will be surprised. Liking Graphene as well. I'm glad I brought it up.
Question. Do you buy graphene coated wire or coat your own ?
gander
Quote from: rollo on August 30, 2018, 08:12:53 AM
Hi Charles,
I buy my graphene and then coat the wires. My current bottle is 500 ml graphene in aqueous dispersion. I just put in new copper with graphene speaker wires and we will see how that goes. In the past two days I put in a digital IC copper with graphene, and a set of analog ICs copper with graphene. So everything is green now.  I have a cable cooker but I'll let these burn in naturally.
Oppo 103, SSD drive
Audio Note 2.1B DAC
Quote from: gander on August 29, 2018, 01:13:06 PM
Gary
Gary
   Gary my bet is 10ga on positive and Neg. and 8ga on ground. My experience is that a smaller Ga. ground makes for a warmer PC. If not must be graphene coating.
gander
#117
Quote from: rollo on August 30, 2018, 08:55:40 AM
Gary
Gary
Let me restate that. I have power cords that are all 8 ga, and I have power cords that are all 10 ga. I don't use differing wire sizes in a power cord. All my current power cords are with graphene.
Gary
Oppo 103, SSD drive
Audio Note 2.1B DAC
Quote from: gander on August 30, 2018, 09:40:13 AM
Gary
Cool.  8)
dflee
It's been a long time commin (CSNY).
Remembered to get dowels at a hardware store a while back for my speakers.
My speakers have a 10" firing forward and a 10" firing rear, both active. so I wasn't sure
if the dowel tweek was going to work.
Got 1 1/4" so I could use the spikes as stops. Spikes don't touch the floor with about 1/4" play from the dowel.
Haven't been able to listen to music yet but gotta tell you what's goin on.
My wife has the multi disc cd player full of an audio book and has listened to the book for
a while now (28 discs) and I put the dowels in between her listening session. The narrators voice
became way more clear and pronounced. I've got the telly hooked up through the stereo and it has
made a distinguishable difference. Cleaner and more clear. Can't wait to put some music on.
Dowels are probably poplar wood (store didn't know) and cost me six bucks for four foot. Now I'm
wondering what other woods would do.
Thanks Gary.
Don
