Stan Killian - Unified (CD)
Anew sax talent. Straight ahead jazz.
mgalusha
The Classical Jazz Quartet - Tchaikovsky's Nutcracker
Silver Vibes With Trombones And Rhythm
Lionel Hampton | Format: Vinyl
Columbia 6-eye I bought sealed in Fort Lauderdale.
Barry (NJ)
Barry (NJ)
The Best of Eric Clapton Timepieces
Eric Clapton | Format: Audio CD
It's Monk's Time
Thelonious Monk | Format: 180g vinyl
First listen of something I bought month's ago while shopping with Bill and Mrs. Bill.
samples;
http://www.amazon.com/gp/recsradio/radio/B0000AVHBM/ref=pd_krex_dp_a
Thelonious Monk With John Coltrane
John Coltrane, Thelonious Monk | Format: vinyl
Had to play 1st tune twice on last album to 'get it', but after that it was an enjoyable listen. Let's see what we do with Coltrane in the mix.
samples;
http://www.amazon.com/gp/recsradio/radio/B000000Y2F/ref=pd_krex_dp_a
After cleaning and re-lubing my TT bearing I found myself rechecking all my other settings, VTA, anti-skate, cartridge loading, speed controller, etc. So I'm not indulging in some sonic masterpieces to fine tune things (and they do sound very good). Just a side of each.
New agey, mostly electronic keyboards, catchy songs, and ooohh the sonics on this.
A sonic classic
I remember seeing this tour live, and it was truly as amazing as captured on this album
Yes, that Lyle Mays, from the Pat Metheny group. If you like Pat you must hear Lyle's first two solo disks if you can find them. Great music (you can certainly hear his influence on Pat's music) and great sonics.
The Flaming Lips – The Soft Bulletin
Starting another round of sonic sides (LP) ...
All the Oregon releases on ECM are wonderful
Another ECM gem
The Rolling Stones: Aftermath
London LP
Larry Carlton: On Solid Ground
MCA LP
