Anyone here use Vibrapods?
Started by jimbones, February 19, 2020, 10:51:38 AM
ejk
Quote from: Response Audio on February 26, 2025, 02:06:18 PM
After trying several footers under one of our DHT preamps, the only one that worked for this piece was the original VibroPod. Different materials and densities will always provide different results. The hard part is finding what works for a specific component. One size does not fit all and you could easily end up with different products throughout your system.
I use the rubber and cork squares. Doesn't seem to affect sound either way. For some reason my mind likes this type of method versus a metal cone for some reason. Im in the camp of anti vibration versus what you would say would be to transfer the energy downward.
I've got extra rubber and cork squares that I no longer use under components. But will use them under cables soon for the first time. I have engineered flooring on a concrete slab, which I think might put vibrations into the cables. I have quite a few and will put them under the UberBUSS as well
