Subwoofers- Abandon All Hope Ye Who Enter Here...
Started by James Edward, January 30, 2021, 03:37:11 PM
Quote from: James Edward on February 08, 2021, 07:04:50 AM
40 hz crossover- 50 hz brought in slight congestion, not boom, but a tad congested.
Most likely because at a 50Hz crossover point there is an bunch of signal that is getting played through both the subs and the mains and since they are not placed in different spots in the room you are getting time alignment errors between the sound emanating from both speakers. With the crossover set lower the natural fall off of the main speakers is preventing "cross-contamination" with the sub. Since the main speakers are playing full range you want to make sure that the subs are only doing what the mains cannot and not replicating anything that they alradey handle.
James Edward
I am using the speaker level inputs as in the 'REL way' of doing things, so I can't do what Emil suggested- however, some other woofers do allow on the fly adjustments via a phone app. I could see this being especially useful where there is shared duty between HT and music. Luckily I'm just doing music with this sub.
As far as the -3 db point of my speakers, the manufacturer specifies 32 hz. This may be so in a perfect room with ideal placement, neither of which I have. When I use my sound check cd, I come in closer to 40 hz. So I basically am doing what Charles suggests. It is a front firing sub.
To further elaborate on the crossover point- the Hsu uses a 24db/octave slope- this makes it a pretty clean break at the crossover point. Other manufacturers may do the same- I don't know.
Chord Qutest DAC
  Appears you have a good handle on the set up. If you can have the centerline of the driver 22% of your ceiling height off the floor even better. Try it.
James Edward
Not a technical post- but man, 'The Bach Gamut' with Virgil Fox Reference Recording has taken on new life. It's true most music doesn't have much content below ~ 32 Hz, but this album does. My dog was just looking around barking, for no apparent reason other the house vibrating. In a very good way!
Chord Qutest DAC
Quote from: James Edward on February 17, 2021, 11:11:05 AM
Glad the Hsu is working out well, and hopefully, your dog is able to enjoy music at higher frequencies 🎼
A good one Try Gladiator sound track as well as the Thin Red Line Harry Pearson would play them for us to show off the Bass.
