Author Topic: Cable Support Plate  (Read 12607 times)
Cable Support Plate
« on: February 11, 2021, 09:32:01 PM »
Check this out. An outlet cover that has brackets to help hold heavy audiophile power cables in place.
A bit pricey, but a really good idea.
TAS Article: https://www.theabsolutesound.com/articles/an-interview-with-john-bring-of-cable-support-plate
https://www.cablesupportplate.com/products
« Last Edit: February 11, 2021, 09:39:16 PM by tmazz »
Re: Cable Support Plate
« Reply #1 on: February 11, 2021, 09:38:01 PM »
Brilliant!  :thumb:
Offline James Edward
« Reply #2 on: February 12, 2021, 04:47:29 AM »
Speaking of this- what do you do at the back of the equipment itself? I find that an issue with my power cords. I currently (no pun intended) use a folded up paper towel as a support, as the IEC outlet is no match for a beefy cord.
Esoteric K-07X
« Reply #3 on: February 12, 2021, 05:54:13 AM »
I actually made a kind of sling to hold the cord on the back of my Hagerman phono stage. Just a cord looped on a clip. The clip hooks onto the top of the unit and the cord goes down and around the plug then back up to the clip. I used a slipknot loop so I can adjust the tension. Works like a charm.
« Reply #4 on: February 12, 2021, 08:12:57 AM »
  Great idea if you have receptacles that are not tight. I use Furutch NCF, Voodoo and PIAudio. ALL grip like a like a Pitbull. Zero sagging. Where I have sagging is at IEC connection with certain PCs.
Offline Folsom
« Reply #5 on: February 12, 2021, 10:48:36 AM »
If you turn the socket "upside down" it'll hold itself generally.
« Reply #6 on: February 12, 2021, 10:51:45 AM »
Yeah,  the "commercial" installation.  The ground pin is in control.
« Reply #7 on: February 13, 2021, 08:11:40 AM »
   Exactly Jim. One can wrap IEC with tape or use a support between underside of IEC and shelf. I found some old Mapleshade cork/rubber isolation ft. Split them in half and were a perfect fit for every component. Lucky find.
« Reply #8 on: May 21, 2021, 10:53:53 AM »
Brilliant!  :thumb:
 Yes agree however a rip off at $100 for mold injected plastic product.
« Reply #9 on: May 22, 2021, 09:12:58 PM »
Just for the record, it states on their web site (shown in the original post in this thread) that these plates are manufactured using a 3D Printing technology, so they are not injection molded.
But that said,  the $100 price is no more of a rip off than anything else in this hobby. Hi End audio products are generally not priced based on the cost of production, but rather based on what the manufacturer thinks will be the perceived value to the customer of the improvement they get to their system. Do you really think that the costs of the parts and assembly of a $32k DAC justifies that price? Of course not,  they price it at $32k because they think there are enough audiophiles out there that will think it provides $32k worth of performance. This case is no different. If enough people think that it is worth $100 to keep their power cords from pulling out or away from the plugs, then they will sell a lot of them and be able to maintain that price. If it does not sell well at $100 the company will have top decide if it is worth lowering the price to make more sales or should they just kill the product. That is just simple supply and demand economics. Any rational business will sell their product at the highest price they can get without deminishing total profits.
« Reply #10 on: May 22, 2021, 10:04:24 PM »
I guess I'm irrational  :thumb:
« Reply #11 on: May 23, 2021, 07:01:49 AM »
Or raise the price and sell more lol  :rofl:
« Reply #12 on: May 23, 2021, 07:07:29 AM »
 Plastic for $100 IMHO is a rip Mommy. A 32K DAC is a rip as well. Well unless you can afford it.
« Last Edit: May 23, 2021, 07:09:08 AM by rollo »
« Reply #13 on: May 23, 2021, 07:45:11 AM »
These days you can almost buy a 3D printer for the cost of two of the 2 plug style for those faceplates and make them and other things as well.
Always wanted to try one out.  Have a few other ideas for parts that would be to expensive to mfg. but could be 3D printed.
Online S Clark
« Reply #14 on: May 23, 2021, 08:07:14 AM »
It looks like something I could make with a hack saw, a piece of pvc, a face plate, and tube of epoxy.  If I wanted to get fancy, I could drill a few holes and use a few toothpicks, a couple of rubber bands, and hold everything in place and together while the glue dries.  Looks like a $10 and 10 minute project.
