DUST vs. HEAT
Started by StereoNut, February 20, 2021, 08:10:55 PM
rajacat
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
StereoNut
Quote from: James Edward on February 23, 2021, 02:08:27 PM
You're moving? I'll hook you up with a great real estate agent. Ya gotta watch those guys.
:rofl: :rofl: :rofl:
No worries Jim. We're not going far. Still be "on the Island".
SN
dflee
#18
SN:
Do you leave your system on or do you turn it all off?
If the system gets hot while playing how long would
you have to wait before covering?
Duh! just read your equipment, it will take a while to cool.
Don
Quote from: rollo on February 23, 2021, 10:28:30 AM
  The question at hand is. Does your gear put out heat to begin with ? If so if you can keep some room from walls and vent clg. a non issue.
All equipment puts out heat, it is just a matter of how much. Bill is using a tubed pre and a Moscode 600 power amp that has fan driven cooling on the output MOSFETs as well a 6 tubes, so he does have a significant amount of heat to dissipate.
