Author Topic: Beefing Up An Old Speaker Cabinet  (Read 8666 times)
Offline James Edward
« on: May 10, 2021, 07:06:31 PM »
I’m helping a friend refurbish a 40 year old pair of SEAS speakers. I had SG Custom Sound rebuild the crossovers, and consulted with Madisound about replacement drivers which are on the way.
The cabinets themselves seem a little ‘ringy’ to me. Since the crossovers are finished, and the drivers are spec’d for the original cabinet dimensions (it’s a 2 cabinet design, a little like a WATT/Puppy), what options are available to deaden the box? I would imagine much internal bracing would alter the volume- is this much of a concern? The woofer cabinet is ~ 59 liters.
Would a Dynamat product be a solution? Or am I overthinking this? Would a few crossbars inside make much of a difference to the box volume to affect much of anything?
Any thoughts or suggestions appreciated. My friend is a carpenter and craftsman, so most ideas could probably be implemented without much trouble.
Thanks as always.
Esoteric K-07X
Offline Jack
Re: Beefing Up An Old Speaker Cabinet
« Reply #1 on: May 10, 2021, 08:24:17 PM »
Might want to ask Danny at GR Research.
Vista Phono II Mk II
Jays Audio CDT3 Mk III
Supratek Cabernet
Kinki Studio EX-B7's
Holo Audio May KTE
Auralic Aries G2.2
Verity Otello/Nola KO
(4) Rythmik F12SE
(2) Puritan PSM-156
Tubulus USB & AES
Wireworld IC's and SC's
« Reply #2 on: May 10, 2021, 08:31:23 PM »
Crossbars would have a negligible effect of the volume and are usually a good idea ( I like dowel rods).  For damping side walls, the No Rez that Danny sells is a good product. It also has little effect on internal volume, since it is mostly a very dense open cell foam.  It does need a clean surface to stick.
« Reply #3 on: May 11, 2021, 08:34:36 AM »
  Sound advice. Agree 100%.
« Reply #4 on: June 12, 2021, 02:08:25 PM »
Just a follow-up… I’ve settled on this- it will serve to beef up the box a bit and also eliminate the need for the fiberglass insulation, resulting in a neater project.
https://www.parts-express.com/Sonic-Barrier-1-1-4-3-Layer-Damping-Material-w-PSA-18-x-24-260-535
My friend still wants to refinish the cabinets, but the crossovers are rebuilt, and the speaker drivers are in. I’ll post some pics when these babies are singing. I should say I’ll TRY and post some pics!
Rebuilt crossovers done by Scott at SG Custom Sound Douglaston, NY
Drivers from Madisound- Brian was VERY helpful in getting drivers that fit and corresponded to the original T/S parameters.
I guess the proof will be in the pudding when these are finally together.
Esoteric K-07X
« Reply #5 on: June 12, 2021, 02:32:03 PM »
Yes, pls keep us posted. As to posting pics, I feel your pain… I’m able to post online pics, but none from my iPhoto library….  not yet at least  :lol:  the old heic, jpg, jpeg problem
« Reply #6 on: June 16, 2021, 08:14:52 AM »
  Decent choice however No-Rez is King in that department. I would install wood dowels forced into place to stiffen cabinet. Have fun.
« Reply #7 on: May 02, 2023, 07:20:42 AM »
They are finally together- after two years! I’ll figure out a way to get some pictures on here. They sound good too- props to SG Custom Sound for the crossovers, and Madisound for all the back and forth regarding drivers that would fit both the cabinet and original specifications- these were purchased in 1980!
A little tung oil rub and the cabinets don’t look too shabby either.
Thanks to all who gave suggestions.
Esoteric K-07X
« Reply #8 on: May 02, 2023, 09:56:46 AM »
Great news! Would enjoy seeing the pics. Any idea what format the pics you’ll be posting are? jpeg,jpg, heic…?
« Last Edit: May 02, 2023, 10:13:00 AM by Nick B »
« Reply #9 on: May 02, 2023, 10:03:28 AM »
Pictures!!
« Reply #10 on: May 02, 2023, 07:34:18 PM »
+1
