I put on where the refrigerator was plugged in, another on the washing machine. I think putting them at the potential source of noise might be better than on the system outlet.
Good idea Bob. I have a few of them in my stereo junk draw that have been supplanted by other stuff in my system. I never really thought about using them in other parts of the house.
I will have to give that a try.
Don't forget to use them on the phase opposite the one your system is on. Remember: the Neutral is common to both phases. Load to Neutral noise contamination is common to both. Applying a QuietLine or other Load to Neutral device is always best placed at the same point as the offender.
Offenders:
Wall warts
Refrigerator
Freezer
Dimmer
Computer
TV
Cable or satellite receiver
Digital clocks
Tool chargers - they are some of the worst
Surveillance cameras
Any lamp with an LED or fluorescent bulb. Better yet, throw those MFers away! A couple of bucks a month is a small price to pay!
Again, if you are capable and confident to do do, go around the house once a year and tighten the screws on every receptacle and switch. Oxidation = RFI due to micro-arcing.
Clean every plug in the house and treat with a good contact enhancer.
[sidebar: clean all of your interconnects and speaker connections regularly. This is particularly important if you are a smoker. Electrical connections have an affinity for smokey ions]
Do those last three things one room at a time, say every week or month to make it not a drudgery...
You will be amazed at the improvement in SQ due to noise reduction, especially in the in the context of space, depth and width of soundstage.
Again: everything effects (and affects) everything.
