Author Topic: Burning in Capacitors  (Read 7682 times)
« on: October 18, 2022, 10:51:01 AM »
I've got several pairs of caps in for potential crossover upgrades.
So, about burn in...
I'll be on vacation for about two weeks soon, and I'm thinking about playing white noise through them in parallel to a midwoofer.  Will this be effective?
Re: Burning in Capacitors
« Reply #1 on: October 18, 2022, 01:11:11 PM »
What amp are you going to use?
Generally speaking this should work well. When I was in my tryig many capacitors mode, I took and old analog SS receiver mistuned to where the music was breaking up and I had resistor banks where I would be able to use both series connections and parallel connections.  You could hear the music sing from the caps being microphonic.  That is when I started mechanically damping components used in internal crossovers.
« Reply #2 on: October 18, 2022, 02:55:10 PM »
I can use a little chip amp and a tuner, or a HT receiver. I could even leave my old Soundcraftsmen amp hooked to a Carver Pre/Tuner.   Is higher volume better or does it matter?  Source? White noise or Beethoven's 5th on repeat? I'll set it on a tile floor with nothing around it... just in case.
« Reply #3 on: October 18, 2022, 06:20:33 PM »
White noise is equal energy in each octave, pink noise decreases in amplitude with frequency and music has ~50% of its energy below 300-350Hz.  I always use white noise OR an old Purist Audio break-in disc that has clicks, pops, frequency sweeps, triangular and square waves mixed into a constant amplitude white noise track.  That way there are transients embedded into the track.
When do you leave?
« Reply #4 on: October 18, 2022, 07:41:58 PM »
When do you leave?
Saturday. Your welcome to come house sit. Listen to all the records you want, but stay out of the wine cellar...
We fly to Germany, then cruise the Danube to Budapest and spend a couple of more days there.  We had a trip to Spain all set when Covid rocked the world.  We are looking forward to traveling again.
« Last Edit: October 18, 2022, 07:46:44 PM by S Clark »
« Reply #5 on: October 18, 2022, 10:26:31 PM »
When do you leave?
Check your snail mail before you leave...
« Reply #6 on: October 20, 2022, 12:29:40 PM »
I've got two 6.8 caps, two 1.0 caps, and four .1 caps to break in.   Can I parallel them all in ~ 16 uF and put them in front of a 5.5" 8 ohm midwoofer to play while I'm away for vacation (and just another midwoofer on the other channel)?  Is it better to put 7 uF per channel into two speakers?  High, medium, or low volume?
« Last Edit: October 20, 2022, 12:31:13 PM by S Clark »
« Reply #7 on: October 20, 2022, 03:35:19 PM »
I would just parallel them... but I take the easy way. :D
« Reply #8 on: October 20, 2022, 03:47:19 PM »
I like easy.   :D
Offline Folsom
« Reply #9 on: November 21, 2022, 12:24:16 PM »
Any feedback yet on cap swaps?
« Reply #10 on: November 21, 2022, 06:51:21 PM »
Sorry, no.  I'm over Covid sort of... but my laziness seems to have gotten worse.  The crossovers have been pulled, and I'm looking at internal hook up wire for inside the cabinets.  I took some shortcuts when I built the speakers years ago, and I'm going to go back and re wire them.
« Reply #11 on: November 21, 2022, 09:43:37 PM »
Oh, crap!  Sorry you got C19.  It sucks and my lethargy lasted 2-3 weeks all 3 times.  Lots of water, my friend.
There is always the recommendations made a few days ago.  The resveratrol, zinc, D and other regimens will encourage autophagy to help clear the leftovers.
