Author Topic: Maestro AC Outlet  (Read 13257 times)
Offline Emil
Maestro AC Outlet
« on: January 09, 2023, 10:17:58 AM »
https://www.cruzefirstaudio.com/maestro
90 bucks. Why not?
Well I'll be damned. This made an audible difference for the better!
Quieter background. Tighter bass. Smoother, more musical presentation.
Power of suggestion? Dunno. I can remove it and reinstall the heavy duty looking Levitan outlet I had but that's a pain in the ass. I'm enjoying what I'm hearing even if it is.
    --Ice Cube
Offline GDHAL
Re: Maestro AC Outlet
« Reply #1 on: January 09, 2023, 11:10:36 AM »
I can believe that it made an improvement, especially if the previous outlet / plug connection was loose.
Many favorable reports about Maestro outlets (subjective anecdotal evidence if you will) can be found on other forums.
Best of luck with them (or it if only one). :)
http://halr.x10.mx/other.html
« Reply #2 on: January 09, 2023, 11:50:34 AM »
  Yes they can make a difference. PIAudio makes a VG one. Furutech though is my favorite. The VooDoo all copper is VG as well.
Offline James Edward
« Reply #3 on: January 09, 2023, 12:23:32 PM »
I also believe in the power of the outlet. PI Dave was good enough to send me one a while back and Tmazz summed it up nicely… I don’t know if I’d believe it if I hadn’t heard it with my own ears.
https://www.audionervosa.com/index.php?topic=8482.msg106736#msg106736
Esoteric K-07X
« Reply #4 on: January 09, 2023, 12:36:43 PM »
  Yes PIAudio one is VG. Similar to Rhodium. A neutral presentation. Furutech Gold over copper is warm, all Copper a tad bright. I have compared each of them to each other in a Digibuss. Furutech describes them on their site.
Offline DRN
« Reply #5 on: January 09, 2023, 06:26:49 PM »
I use the Maestros here for the last5 years or so. Had the Furutech Rhodium models $180 each sold them
These were better to my liking. Depends on your  system.
Rogue CM Dark 2SB2000Pro
Fritz Carrera Be SA Stands
CA Emotion SE CMB Carbon Satisfy Arm Phoenix Falcon PS
AT33PTG II Shelter 501 lll
Darlington DP8B Su7
Wywires Silver Series Platinum AES
Yggdrasil+LIM CECTL5 Trans
BS Node 2i Qobuz
Room all treated
Offline ejk
  • Did I say no dropouts ?
« Reply #6 on: January 09, 2023, 07:15:24 PM »
Don't know what type of outlet I have but I know it came from Fremer so hopefully it's good
Aric Audio Super 6SN7 Line, Orchard Audio Starkrimson Ultra,Quicksilver Mid Monos, Lumin U2 Mini, Denafrips Pontus II 12th-1,Denafrips Iris DDC, Spatial Audio M3 Saphire, Hapa Audio Interconnects, TWL power cords,TWL speaker cables, Wireworld USB, i2s
« Reply #7 on: January 10, 2023, 06:53:01 AM »
Several years ago at AC, member Big Red Machine built a multi outlet device with multiple parallel high end outlets and sent it out on tour.  They each clearly sounded different.  The Maestro was my favorite.
Offline GDHAL
« Reply #8 on: January 10, 2023, 07:26:07 AM »
Hi S Clark. That reads like a really kewl idea! A question about that, if you don't mind. The multi-outlet device with parallel high-end outlets had to have been plugged into an outlet of some type. In your opinion is it possible (I imagine at least conceivable) that the outlet it was plugged into could somehow have influenced the characteristics of other outlets? This would be akin to plugging different amplifiers into the same preamplifier and then observing if any differences. No?
I've read nothing but good things about Maestro outlets.  :thumb: But suppose the multi-outlet device with parallel high-end outlets was itself plugged into a Maestro outlet. You get (read) my point.
« Reply #9 on: January 10, 2023, 08:28:10 AM »
   Rhodium is a bitch to break in. Takes 500 hours to stop the hardness. Dave of PIAudio and I almost gave up after 300 hours. Very open big stage but Hi Fi sounding not musical IMHO.
Offline Folsom
« Reply #10 on: January 10, 2023, 01:23:05 PM »
Rhodium isn't for me. It's thin and weird sounding.
I like what Dave does, polishing.
« Reply #11 on: January 10, 2023, 02:14:00 PM »
  Has its advantages in transparency and openness but not musical.
Offline ejk
« Reply #12 on: January 10, 2023, 07:32:24 PM »
Weren't Hubbell outlets popular years back?
Offline ejk
Offline Folsom
« Reply #14 on: January 10, 2023, 08:42:24 PM »
Still popular with me.
