opinions wanted on subwoofers
Started by Nick B, July 09, 2023, 07:46:01 PM
Quote from: Jack on March 14, 2024, 06:46:13 PM
Did you check the fuse on the sub amp?
No, will look for it right now....
Quote from: Nick B on March 14, 2024, 06:57:47 PM
Ok, the fuse in the IEC was shot. There was a spare in the IEC and I used that one. With the toggle in the off position, I got the standard red LED for a fraction of a second and it blew again.
Jack
OK, apparently that amp has issues and was the cause of the noises you were hearing all along.  At least since you have the subs close to the rack on the inside of the speakers you can just use one of them with both of the cables until Brian sends you a new amp.
Vista Phono II Mk II
Jays Audio CDT3 Mk 3
Aric Audio Motherlode XL
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
Quote from: Jack on March 14, 2024, 07:51:25 PM
Ok, then I'll run the line out on that one side.
When it comes to your issues it is the typical what died first that killed it's friends?
Quote from: P.I. on March 14, 2024, 08:27:50 PM
Yikes, have I committed "audiocide"?? A misbehavin' sub ain't my friend 💥 Hopefully Brian at Rythmik can make me love subs again.....at least for a time ⏰
Quote from: Nick B on March 14, 2024, 08:33:41 PM
You were merely complicit in observing a death wish come to pass.
Brian's customer service has been stellar in the past.  It all depends upon his ability to source his goods.  He is a very smart, nice human.
Quote from: P.I. on March 14, 2024, 08:37:32 PM
Yes, the sub experiment went south a bit. I'm not ragging on Rythmik or Brian at all. These are nicely made subs, with limitations on the quality of some parts. Stuff happens and Brian was prompt to respond regarding my concern of a loud "thump". And he responded within a couple of hours after I told him him the left sub died. If I were ticked off at Brian and Rythmik, I wouldn't have offered to remove the amp, disconnect the wires, find a box for it, package it securely and just ship the amp back and not the whole sub. The boxing, packaging and my time would be on me. They're a small company from what I know and I'm trying to save them a few dollars in shipping. Companies should have unhappy customers like me who try to resolve things amicably and save them money in the process.
Jack
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
Jack
Just a lot different amp than what's in my four.
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
With how busy Rythmik is, I'm curious if they'll try and fix it or just send a new one. Either way works for me....
Jack
I doubt that they have anyone to fix them as their just Hypex circuit boards.  Likely Brian will just send you a new one a decide what to do with the old one once he gets it back.  Him fixing the old one and sending it back at some point is not an option I would accept.
Erhard Elvis Mk2
Aqua La Scala Mk3
Auralic Aries G2.2
Verity Arindal
(4) Rythmik F12SE
(2) Kinki Tai-Hang
Veritas & TWL PC's
DRN
#148
The HX310 PEQ mentioned is not the amp I had in my subs.
I had A370XLR3
Rogue CM Dark 2 SVS SB2000Pro Sonus Faber Sonetto 2  CA Emotion SE CMB Carbon Satisfy Arm Phoenix Falcon PS
Hanna ML Shelter 501 lll
Hagerman Trumpet mc3 Nos tubes
Belden 8402 Duelund 12ga SC
Yggdrasil+LIM CECTL5 Trans
Wiim ultra Qobuz
Surge x power
Well, my Rythmik L12 is off to Texas to be repaired. I did my best to disconnect that amp, but the clips are impossible to get off the sub and there's hardly any room to maneuver in the cabinet. So the whole thing needs to go back.
Tweaking my back was a reminder why I don't want to deal with difficult to lift/carry components. Brian at  Rythmik has been on top of things and pleasant to deal with.
