The Monoliths II speakers with dspNexus 2x8
Started by HAL, December 30, 2023, 01:12:47 PM
HAL
Time to update the original Monoliths speakers to the Monoliths II's.
Replacing the BG NEO10 planars with the new Radian Audio LM10n planar midranges that are in the Magnetar II speakers.
The dspNexus 2x8 system DSP crossover design will be updated to use the LM10n planars with the GR NEO3 planar tweeters.
Time to wire the planars with Analysis Plus Oval 16 cable to the Parasound Z-Amp v3's for testing.
HAL
Have the two Monoliths II's wired to start testing.
Now to connect the Parasound Z-Amp v3 to use with CLIO for the frequency response measurements.
Quote from: HAL on December 31, 2023, 07:01:28 PM
HAL
The Monoliths II are setup for some testing of the new Radian Audio LM10n planar as a midrange.  The Parasound Z-Amp v3 fits besides the planars for 2' driver cables.
The CLIO system is setup with the calibrated measurement mic at center of tweeter height.
HAL
First set of measurements are done and DSP crossover for the Monoliths II's has been updated.
Have the dspNexus 2x8 running the new crossover and have signal through the planars.
The Parasound Z-AMP v3 is driving the two planars.  Now to setup the 2x12 servo subs integrated with the planars.
Quote from: HAL on January 02, 2024, 05:28:57 PM
Are you done with the acoustic treatments?
HAL
Nick,
No.  There is a lot more to do for treatments.
Had to make new servo sub cables today to get the system connected.
Got the Monoliths II's playing music from the dspNexus 2x8.  Still some level checks to do to set the gains for each driver.
HAL
Did some DSP crossover rework of the Monoliths II with the CLIO Pocket system measurements and this is the on-axis farfield response in the room.
Still have room modes to work on below 200Hz and possibly some tweeter response flattening that can be done.
HAL
Back to the Monoliths2's to try out the new Radian Audio LT3.2 planar tweeter.
First I modified the tweeter by removing the rear cup.  I want dipole radiation like the LM10n
A friend 3D printed an adapter to go between the original BG NEO3PDR/GR NEO3 mount and the LT3.2 mounting pattern.  Not saying it is going to work well, just a place to start.  Radian offers the tweeter in their own waveguide for use.
Moded both the prototype baffles with both the LM10n and LT3.2 for testing and listening.
