Author Topic: The AGN II speaker system build  (Read 23445 times)
« on: April 25, 2024, 05:03:31 AM »
The AGN II line array speaker will be a 2-way with 6 Radian Audio LM10n planars covering the 200Hz to 20KHz range and 6x12 OB H-Frame servo subs covering 14Hz to 200Hz.
The dspNexus 2x8 DSP system with AKM AK4499EX DAC's will be the DSP crossover and input selection use.
The two 6x12 modular OB H-Frame servo sub cabinets are assembled and ready for painting.  These are Jay's modular cabinet flat packs I assembled.  These have a top plate the same size as the sub module top.  He also makes tops with overhangs.
Drop them off next week for painting.  The last 6-12in servo subs arrive this week.
Re: The AGN II speaker system build
« Reply #1 on: May 17, 2024, 11:46:59 AM »
The 12 open baffle sub cabinets are being painted with an automotive 8 step finish.  Here are some pics of the modules and base:
« Reply #2 on: May 17, 2024, 09:28:05 PM »
Looking good, Rich! Nothing like having a professional paint job. My spray results are ok, but that's all...
« Reply #3 on: May 18, 2024, 06:55:06 PM »
Nick,
Thanks!
They always do a great finish job for me.
« Reply #4 on: May 21, 2024, 11:55:23 AM »
All the 12 sub modules are now painted and here.
A low gloss Hot Rod Black color.  They do a great job on finishing!
« Reply #5 on: May 25, 2024, 07:20:12 PM »
All the sub modules, tops and bases painted and ready for servo sub driver installation.  :D
« Reply #6 on: May 26, 2024, 08:37:12 AM »
« Reply #7 on: May 31, 2024, 04:37:36 PM »
The first Servo sub getting installed in the OB modular cabinets.
« Reply #8 on: June 01, 2024, 06:24:57 PM »
Modules are getting assembled.
One third of the modules are complete.
« Reply #9 on: June 01, 2024, 06:32:18 PM »
Hey Rich,
Looks good. How much do each of these stacking modules weigh and do you need any help lifting them into position?
« Reply #10 on: June 01, 2024, 06:53:02 PM »
Nick,
They are around 25-30lbs each and easy to move around.  I need to weigh one now that they are finished.  The base plate and top cap are under 10lbs each.
I stack them by myself.  Will need a small ladder to put the top modules on.
Went to modular cabinets to prevent having to move heavy large sub cabinets around.  Works well for me.
« Reply #11 on: June 02, 2024, 08:52:16 AM »
Nick,
That's quite manageable and a nice idea.
« Reply #12 on: June 02, 2024, 02:15:29 PM »
Now up to 7 modules complete.  Only 5 more to go then make the amp to driver cable harness.
« Reply #13 on: June 02, 2024, 05:46:57 PM »
Eight modules complete.
Four more servo sub driver installs in the cabinets and then time to make the wiring harness to connect the drivers to the servo amps.
« Reply #14 on: June 03, 2024, 06:14:10 PM »
All twelve sub modules are complete.
Next to bolt the two 6x12 stacks together in their locations.
Then build the wiring harnesses from the sub modules to the servo amps.
