Orchard Audio Unveils 1200 Watt 4-Channel Plate Amplifier at NYC Audio Show
Started by orchardaudio, September 22, 2025, 09:12:07 AM
orchardaudio
Orchard Audio, in collaboration with Soundfield Audio, is proud to announce the debut of a revolutionary new product at the NYC International Audio Show: a 4-channel, 1200 watt plate amplifier with integrated DSP.
A plate amplifier is essentially a self-contained power amp module, typically mounted directly onto the rear panel of a loudspeaker enclosure. It integrates the amplification circuitry, input connections, and a DSP with crossover controls into a single, compact unit. For the listener, it means fewer boxes, shorter signal paths, and a more direct connection between source and transducer (driver). By embedding the amp into the speaker cabinet, designers can optimize the amp-speaker synergy, especially in low-frequency reproduction, where damping factor and driver control are critical.
Orchard Audio's cutting-edge plate amplifier, which uses our award-winning Starkrimson technology, marks a significant leap forward in active speaker design, delivering precision control, immense power, and advanced signal processing—all in a compact plate-mounted form factor. Engineered to meet the demands of high-fidelity enthusiasts and professional audio environments alike, the amplifier offers:
  • Four independent channels of amplification for complex multi-driver configurations
  • 1200 watts of total output power, ensuring dynamic headroom and low distortion
  • Integrated DSP for tuning, and crossover management
  • Modular architecture allows for future firmware updates and customization, giving users long-term flexibility and performance enhancements
The plate amplifier will be installed in a Soundfield Audio 1212C full range cardioid loudspeaker. This speaker features:
  • Wide dispersion planar super tweeter
  • 12-inch Neodymium coaxial point source main driver with ring radiator compression driver
  • 2 x 12-inch subwoofers
  • DSP Delayed diffuse field rear-firing planar driver.
Orchard Audio will be in room 107 at the NYC International Audio Show, October 24-26, 2025.
Leo Ayzenshtat, Founder
www.orchardaudio.com
www.facebook.com/orchardaudio
www.twitter.com/orchardaudio
www.instagram.com/orchardaudio
www.linkedin.com/company/orchard-audio-llc
Quote from: orchardaudio on September 22, 2025, 09:12:07 AMOrchard Audio, in collaboration with Soundfield Audio, is proud to announce the debut of a revolutionary new product at the NYC International Audio Show: a 4-channel, 1200 watt plate amplifier with integrated DSP.
That sounds exciting, Leo. I believe AJ is the proprietor of Soundfield. He used to post here some years ago....
orchardaudio
S Clark
Quote from: S Clark on September 23, 2025, 01:23:21 PMAJ has made some very impressive speakers over the years.
AJ thinks a lot about not only what, but how a speaker should sound.  :thumb:
I'm not familiar with the particulars on his designs, but I recall one where he was using some drivers from KEF. I thought that was such an interesting design.
orchardaudio
There has been a change to the room number at the show; Orchard Audio will not be in Room 108.
orchardaudio
