SEparates vs Integrated Amp.
Started by rollo, January 19, 2026, 11:55:01 AM
Quote from: Nick B on January 23, 2026, 08:16:11 PM
Quote from: steve on January 23, 2026, 11:38:51 AM
Quote from: Nick B on January 23, 2026, 09:27:05 AM
Quote from: steve on January 23, 2026, 04:42:45 AM
Quote from: Nick B on January 22, 2026, 09:43:58 AM
Quote from: steve on January 22, 2026, 05:16:43 AM
Quote from: rollo on January 19, 2026, 11:55:01 AMAre separate components really worth it ? Over the years it was never questioned just told separates are better. Especially dual mono everything. We know power supplies are the heart of any component. However is it wise to have several different ones? Lots of magnetic fields, grounding, etc.
Why not just keep it simple with an integrated. Less Cables, cords, rack space. As you know we carry Qualiton by Audio Hungary. I have compared their integrated Amps to their separates. To be honest no difference in sound, stage or noise. Actually a bit quieter.
As a Dealer separates make me money. However we push integrated. We would rather see your dollars go to a better front end or speakers. Any thoughts ?
Excellent questions Charles. As you indicate, separates do not automatically mean improved
sound quality. A few points I hope will clarify what is possible, cutting edge,
with separates that are not possible with an integrated.
When I got into this venture 45 years ago, I had no idea of the rabbit holes, and how deep
I would go, but was worth it. The results are cutting edge.
Here are some thoughts from research and developments.
1. The power supplies in typical designs of all types are far from optimum. But then
this includes both integrated and separate types. However, more gain stages are
often incorporated in an integrated amplifier, thus more problems. There is such a
thing as too simplistic, even in power supplies.
Too few filter sections, separation between stages is further explained with
my attached link (used to be SAS Audio Labs website before retirement).
http://www.godsloveforyouandme.com/theory8a.htm
As an example, the SAS Audio Labs 10A, 11A Line preamplifiers use 6 power supply filter
sections, for just one stage in the preamplifier. This prevents any sort of interference from degrading the musical signal. Those preamplifiers are also designed to separate the L and R channels, explained later in the post.
My monoblock amplifiers are necessary due to separate power transformers and multiple filter
sections for each of 3 power supplies. As such each power supply completely isolates one
gain stage from the others; so absolute minimum musical interference.
The penalty is that each channel requires its own chassis due to physical constraints.
2. As mentioned earlier, the other problem is channel separation. We must minimize the
musical signal in one channel from leaking into the other channel. Not only caused by
common wires, parts, but also from through the air. Musical signal can cross channels
as low as 2khz, or even less.
This problem is frequency sensitive. Bass and rising frequency are the main problems.
Mid/lower mid frequencies are usually where the channel separation is greatest.
A. Bass crossover due to power supply design flaws, including filter design, and common
wires to both channels, including those so called ground wires.
B. As the frequency rises, high frequency crossover is due to proximity of L&R parts,
common wires, and shielding between channels etc. As channel separation weakens due to
rising frequency, the harmonic structure of instruments and spatial information are
altered. Even if we have the correct instrument harmonic structure in the correct
channel, leakage into the other channel will alter the total harmonic structure that
we perceive. It would be a great idea if designers/manufacturers would spec the
channel separation at various frequencies.
I hope this helps in answering questions that the public might have.
Steve,
Thanks for the information and your perspective as a designer.
Respectfully, more than a perspective Nick. A clear difference in spatial,
bass through highs musical enjoyment.
For instance, changing just one decoupling capacitor from electrolytic (DA of 7-10%)
to accurate Polypropylene (DA of 0,02%) allows one to obtain up to 50db deeper into
the inner detail across the decoupling capacitor.
Due to RL, this figure will generally be less at the plate of a tube, per stage.
With one's entire audio system utilizing decoupling capacitors changed to polypropylene,
over the decades, we consistently perceive FR changes in the -132db change vs fundamental,
using the 20log db voltage equation. That equates to 1 part in 4,000,000.
Most probably won't believe of such sonic improvements, and the cost is higher, but imo,
well worth going integrated if maximum enjoyment is to be obtained.
Cheers and all the best.
Thanks for your input, Steve. Always good to get your technical perspective. I appreciate the simplicity of an integrated, but it's just not something I want to try out and invest in right now. I have flexibility with having all separates. I also would have no idea of a reasonably priced integrated that would equal what I'm getting with the Hattor preamp and  Starkrimson amp. I am curious if you ever worked on developing an integrated when you were running SAS.
My apologies Nick. I had to correct a mistake listing "integrated" when it should have
been "separates" in post #11.
I will never go integrated. There is just not sufficient physical room for
a perfect design, with all the parts, best layout etc.
I realize this is cutting edge, but for diyers, if there is room in your separates
to add power supply filtering sections, maybe a little redesign, I would do it.
Thanks for clarifying that, Steve. The majority of the Audio guys that I know only do separates. But I hear there are some very good integrated like the Cary.
Some integrateds are improving a little, but still comparing to typical separates, not cutting
edge of what could be. Unless some company actually manufactures the latest cutting edge, all
will be lost.
Mimir Modified DAC
SAS 20 W Ref Triode 40 W UL
I imagine integrateds from Qualiton (that Charles carries) Accusphase, Cary and some others would be quite good. For me, an integrated doesn't allow for the flexibility I want right now.
Quote from: Nick B on January 25, 2026, 08:37:57 PMI imagine integrateds from Qualiton (that Charles carries) Accusphase, Cary and some others would be quite good. For me, an integrated doesn't allow for the flexibility I want right now.
I agree Nick. That is why I never attempted to design an integrated. Just not enough room
to design it right.
Mimir Modified DAC
Quote from: steve on February 08, 2026, 09:31:12 PM
to design it right.
Steve, There is a bit more flexibility with being able to swap opamps in some of the designs and maybe swap boards as well. But it is still limiting. Someday I might just buy a very good integrated just for a change of pace.
Quote from: Nick B on February 08, 2026, 09:50:23 PM
to design it right.
Yes, there is flexibility with op amp chips, whether in separates or integrated.
Would be able to update chips with minimal fuss. Flexibility is good in case of
tube aging, finding best vacuum tubes, room aberrations etc.
Mimir Modified DAC
