Subwoofer cables (???)
Started by stereofool, June 27, 2008, 11:26:18 AM
stereofool
I should be receiving my pair of ACI Titan XL subs next Tuesday  :drool:!
SO...here is the question...Has anyone had any positive/negative experience with 'subwoofer' interconnects...(these will need to be RCA)? If so, please elaborate.
I've numerous manufacture's IC's lying around already, but almost all of them are 1 meter, and I'm going to need at least 2 meters...in order to have enough room to move the subs to where they need to be.
Any thoughts, or experiences will be appreciated!
Steve
Black Sand Cable
I have tried more then my fair share and I never heard a difference as long as I was using a properly shielded cable.
Based on that, I use good old Canare for my subs and it works rather well.
It does seem that the overall feeling is that IC's really matter in the mids and up... but no one seems to be definitive about bass.  Some IC's probably 'seem' more extended in the bass because of the way they affect the mids and highs.. but then, some probably really ARE more extended in the bass too...
I poked around with the same question but didn't get much info.  I ended up buying a blue jeans cable for my system... but I needed 30'.  If I only needed a 2m pair, I'd probably go a little nicer... Maybe DH Labs.. but I wouldn't spend 'real money' on a sub cable personally.
  Have had good success with solid core wire than stranded wire. However still prefer using ICs than speaker cables.
