bought a dac today
Started by rosconey, October 05, 2008, 10:26:05 AM
rosconey
been thinking about getting a new cd player but just havent been able to pull the trigger on one-
so i started thinking about dac's,and how my hdtv has only digital out for sound-figured if it didnt float my boat i could at least use it with my tv and stop running my tv audio thru the cable box's rca outs-
so i broke down and bought a zero dac,well not just a zero dac but a zero dac with Tianyun ZERO Multifunction Decoders-whatever they are -
ill post more when it arrives
rosconey
upgraded zero dac arrived today :D has a 627 op amp instead of a 2604-
from ebay-Specifications:
~Recevial chip CS8416
~Decode Chip AD1852
~Analogy Opamp chip: OPA627  (For old version it is OPA2604)
~S/N ratio 105dB
~Distortion 0.0005%
~dynamic range: 117dB
~Frequency Response 20Hz-30KHz(±0.5dB)
~analogy output frequency: 2V
~Imput port: one digital optical fibre imput
                      one digital coaxial imput
~Output port: one RCA analogy un-balance output
                       one 6.3mm headphone signal output
~power imput voltage: 100~220V50Hz±10%
~Dimension:240X220X55mm
~Net weight:3kg
out of the box it had no stage or depth,after a song or 2 its started to open up-but the bass was solid out of the box-even if its not my thing i can still use if for my tv and with luck remote the volume with the tv like my last one did
rosconey
thing started to open up nice last night- i would say its worth the 125$ imho
$125!?!?!?  wow
Glad to hear it's sounding good rosco
Here is a review:
Buy on EBay:
rosconey
i just may get some headphones and give the head amp a try-
this is a really nice little unit sound wise-
