Author Topic: Gateway Audio Society - Keep In Touch Thread  (Read 204609 times)
Offline Scott F.
  • ...DOH!....DOH!....DOH!
Re: Gateway Audio Society - Keep In Touch Thread
« Reply #45 on: October 14, 2009, 02:28:26 PM »
OK, this one will blow your mind, follow this link;
http://www.audionervosa.com/index.php?action=mgallery;sa=album;id=32
That should take you to the gallery I created last night called "Cool Shots From RMAF 09"
Seems as if somebody has been viewing them after I uploaded them as they have four views. I only went through them once to get the links for my post.
That said, Lord knows I might have created an album the wrong way. I just checked, it shows up under the User Gallery.
Lemme try reposting the links and see if that works.
Thanks Rich
My brain hurts.....
« Reply #46 on: October 14, 2009, 02:56:26 PM »
Yes, I see it. Maybe it was there before, I tend to ignore long words.
Put future pics into a  "ScottF" folder, make sub directories in there named whatever you want.
The gallery needs some customization to work effectively for us. I'll try to work on it.
Nice pics!
Offline Bob in St. Louis
  • Moderator
« Reply #47 on: October 14, 2009, 04:04:27 PM »
TEST #1:
TEST #2:
TEST #3:
TEST #4
WHHooo HHHOOoooo!!!!!!!!!!!  :yay2: :yay2: :yay2: :yay2: :yay2:
There you go Scott. I've never had to use that method to embed a picture. Kinda weird.
But there you go anyway.
You can {quote} my post to see the versions I tried, and the last one that worked. I ussed the {DIRECT LINK} just below the image and placed the link between the {IMG}{/IMG} thingies.
Bob
  • Moderator
« Reply #48 on: October 14, 2009, 04:07:32 PM »
Awww crap.  :duh
I just noticed your other thread where you figured out how to do the pics.  :roll:
I did them differently than you did, but either way works.
Bob - damn
« Reply #49 on: October 14, 2009, 04:43:15 PM »
Click on the camera icon under your avatar to get to your album.. that's the easiest way to view your gallery...
People seem very polarized about the gallery.. they have no issue or have a lot of issues.. I'm not sure what to do about that.. I've installed the easiest one I know of.. Others I've seen aren't any more intuitive.
Click on gallery, then 'My albums', then 'Add new gallery', and upload photos.. The only somewhat tricky part is copying and pasting the link to the photo.
In this gallery software I don't think you can create multiple albums... You can only put all your photos in 1 place... your own user album.
I can do a more graphical how-to if it helps.  Like any piece of software, it takes a little getting used to..
In any case, I see the photos exist here: http://www.audionervosa.com/index.php?topic=1715.0
So, glad it's working!
Offline Scott F.
« Reply #50 on: October 14, 2009, 05:55:18 PM »
Hiya Carl,
No polarizations going on here. I just needed to play with it for a while to figure out how to use it. No different than any other piece of software  :D Can't say I've mastered it yet, but I will  8)
My brain hurts.....
« Reply #51 on: October 15, 2009, 07:31:22 AM »
Glad you're willing to give it a shot and stick with it, Scott.. thanks!
-Carl
Sturgus
« Reply #52 on: October 15, 2009, 08:15:42 PM »
Looks like I am late to the party but I still made it. The new digs look nice. :D Thanks to the site for having us.
Sturgus
  • Moderator
« Reply #53 on: October 16, 2009, 07:09:44 AM »
Welcome Sturgus!
Bob
« Reply #54 on: October 16, 2009, 07:48:49 AM »
Hi Sturgus
Good to have you hear. Great bunch of guys.
« Reply #55 on: October 16, 2009, 11:53:09 AM »
BIRD!
Offline ampdesigner333
  • WE DELIVER THE DETAIL
    • Digital Amplifier Company
« Reply #56 on: December 16, 2012, 04:14:59 PM »
Hey Hammer, welcome!
....look at that, I just switched from a Newbie to Seeking Help. Guess 20 posts was the cut over  :D
I'm looking for info on the "member group" which apparently isn't something we're allowed to change on our own....  I'm showing up as "seeking help" as well, but I'm a hardware manufacturer......
After a long search, I found your post which seems to indicate that's a status which changes with the number of posts.   Hmmmmmm.....
-Tommy O
Digital Amp Co
  Makers of the "Cherry Amplifier" (R)
      ---- www.CherryAmp.com ----
  • Moderator
« Reply #57 on: December 16, 2012, 05:48:09 PM »
Yes. It's basically a meaningless description of the level of post whoring one has accomplished.
 :lol:
The only way you can change it, would be to post more.
Bob
  • Moderator
« Reply #58 on: December 25, 2014, 11:15:16 AM »
"Bump" for two years of no activity.  :(
« Reply #59 on: June 08, 2020, 11:43:11 AM »
  So Boys whats up.since 2014 ??
