Group Buy Requirements
Started by Carlman, February 10, 2007, 08:08:22 AM
Group buys can be started by anyone that is a current/active member of AudioNervosa with at least 5 discussion posts. (not just links or one-liners)
The person starting the group buy controls how it works however here are some suggestions:
- Group buys should have an end date.  *
- All quantities and discounts must be clear.
- All orders must go to 1 person, who then will handle the deal with the manufacturer.  Basically, as a courtesy, make it as easy as you can on the manufacturer.
Thanks and happy group buying!
* - If you notice a thread is locked, it's because its useful life has expired.  The GB or tour is no longer happening.  You can start a new one, though.
