Help me choose a streamer
Started by evan1, April 13, 2011, 03:00:08 PM
evan1
I'm only concerned with streaming Netflix right now and maybe Pandora . Right now I'm just using my granddaughters Wii to stream Netflix but when she is here on weekends I put it back in her bedroom .I don't want another Blu Ray player . I love the streaming idea so I want to choose between the Apple TV and Roku XDS. Same price but which do you think I will be better off with ?
Are you already an Apple fan? Do you have a iPhone/iPod Touch/iPad you can download the more robust controller app to versus the remote that comes with it? Does your TV have an hdmi port? If yes to all 3, get the Apple TV box.
Otherwise, Roku.
spudco
+1 on the AppleTV.  Just installed one 2 weeks ago and it is fine for netflix, photos/slide shows, internet radio.
It also recognizes "other" remote control codes.  I taught it to respond to a Yamaha receiver code set to use my Pronto.  Took a few seconds and works great.
djdube525
The only downside that I could see with an AppleTV over a Roku was that Roku offers at least one model with 1080p... I believe AppleTV is just 720p.
If that matters to you anyway...
Dave
Quote from: djdube525 on April 14, 2011, 08:54:39 AM
Dave
I think the 720 vs 1080 decision should be driven by basically two things.
1) how big of a screen will you be playing this on? of the screen is 40: or less then 720 could be on the table. At 42" I would start to worry a bit and over 42" I wouldtry to stick with 1080p. Just one man's opinion YMMV.
and
2) What are your other sources? If you have a large screen and a bluray player that you us regularly, the lower resolution of a 720p stream will become quickly noticeable. And while 720p in and of itself is not really that bad, if your frame of reference is the high res output of a bluray watching a 720p stream could possibly become irritating.
Of course one other thing to be concerned with is whether or not your internet connection has the bandwidth to cleanly stream at 1080p. Because no matter how good the picture is, if the stream is constantly pausing because the buffer emptied out, you will tire of it in a hurry.
bpape
IMO, it also depends on the native resolution of the screen coupled with how good the scaling solution is in the screen.  If it's a native 720 set, then stay with 720. If it's 1080 and has a decent scaler, then the 720 could be OK but the 1080 will still negate the need for conversion.
evan1
I have a 50 inch Samsung plasma and it's only 720p. I think that is the highest Netflix streams at this time.
Quote from: evan1 on April 14, 2011, 02:27:46 PM
If your TV ans Netflix both top out at 720 then whether a streamer goes to 1080 is not really something you need to worry about right now.
djdube525
It looks like Netflix can do 1080p based on this...
Which does bring to mind... the PS3 is not a bad streamer/blu-ray combo.
evan1
Quote from: djdube525 on April 15, 2011, 10:48:31 AM
But my TV will not
djdube525
Well... that is something you could rectify.  :thumb:
evan1
Quote from: tmazz on April 15, 2011, 04:57:05 PM
Quote from: djdube525 on April 15, 2011, 03:19:42 PM
Video Nervosa?  #-o
Nah. Did the HT thing years ago but it was won over by Audio Nervosa.
Quote from: evan1 on April 15, 2011, 11:33:36 PM
Video Nervosa?  #-o
My kinda guy!  :thumb:
