Reality Cables vs. Grover S Cables
Started by Carlman, April 24, 2007, 02:29:17 PM
OK, I've heard and observed quite a few Reality vs. Grover comparisons (including my own) and thought I'd start the obvious thread for it.
What do you like about these cables and why?  Is there a clear winner for you and your system?  Let's hear it! :)
Christof
I also would like to hear of any comparisons.  I just started vertical biamping so I need to go cable shopping.....I'm on the fence b/t Greg's Reality Cables & Grover's both of which I've been informed are a wonderful for the $.
Anyone?
Christof....
In a nutshell...
Do you prefer a smooth sound....or a more detailed sound ? Those are the difference's that I hear between the two.
Same here, LW.  Gregg's done some new 'special' cable that seems to do a little more of both detail and smoothness, though... I'll be sticking with the new 'special's'.
