George Wright AU -70 in the haus
Started by topround, December 18, 2011, 07:04:04 AM
topround
I picked up a pair on Geroge Wright mono's
the AU -70's two KT 88 perside, I really did not want mono's but they only come in mono. I am looking to get the power I need with as few tubes in the power stage as possible.
So I went from 2 stages of push pull( 4 el34 per side) to one stage of push pull(2 KT 88 per side)and really like it.
Of course the best would be only one tube per side, but I don't think they make any 60 -70 watt single tube designs. At least one that I could afford.
Currently running the table direct into the amps using the amps gain controls as volume, and it works great, really great.
Now I need to the hook the Micro Seiki back up and get a great phono stage and I should be done...really.
One thing that bothers me is that I need 2 power cords, trying to find one is hard enough, two is a real pain and expensive.
  Looking good there. GW made made great amps. Those amps really like Essence ESP powercords. You can find them used at the Cable Company.
topround
Those look nice, Mike. Welcome to the world of no preamp... ;)
Quote from: topround on December 18, 2011, 07:04:04 AM
:rofl: :rofl: That's a good one Mike.  :rofl: :rofl:
You'll be done when they throw the dirt on you.  :roll:
(Why should you be any different than the rest of us. :duh )
