N.Y.A.L. Moscode 600 Amp
Started by StereoNut, January 16, 2013, 05:08:58 PM
StereoNut
Quote from: Lizard_king on January 22, 2013, 10:56:29 AM
Do NOT run thed syetm for consectutive days! Play it each day for a few hours at a time, twice daily.
Quote from: topround on January 16, 2013, 06:44:09 PM
I hope when it is all hooked  up correctly( don't forget to plug it in) that it sounds glorious.
If it doesn't...don't fret it probably needs a bunch of burn in
get a cheap cd player and run it in repeat mode for a few days, don't worry about the tubes...they need to be burned in as well.
turn it off for a few hours every day
Do it for a week! Sounds crazy but it will sound a lot better
Paul
I've heeded to Charles advice and have been running the system no longer than 5 hours at any one time. (I usually turn it on at night when I get home from work and turn it off at bedtime.)
On the weekend, I got to run 2 "cycles" (5 hours on/5 hours off) each day because I was home to do so.
Some was just running the FM tuner to just get signal through the system and other hours were actually listening.
SN
topround
Silence is not a good sign
any thoughts on how it sounds?
StereoNut
Quote from: topround on January 22, 2013, 03:54:31 PM
Mike
Thanks for your interest here.
I started a new thread with comments about BOTH the Dodd VGP Pre-amp and the NYAL Moscode 600 Amp, hoping it would help to simplify things.
http://www.audionervosa.com/index.php?topic=4410.msg57894;topicseen#msg57894
I hope this new thread begins to answer a few questions for everyone.
SN
