N.Y.A.L. Moscode 600 Amp
Started by StereoNut, January 16, 2013, 05:08:58 PM
StereoNut
After 4 months and 1 day, it's finally home!  I just gotta drop in the 2 big tubes and we're ready to go!
Wow....that was quick turnaround....
Let the break'in begin.....hope they match up well... 8) :beer:
StereoNut
Quote from: lonewolfny42 on January 16, 2013, 05:18:46 PM
Your lips to God's ears, Wolfie! :thumb:
You now have to update this...
Quote• Naim Electronics (NAP250, Modded SNAPS & NAC42 w/outboard phono)
• EE Minimax DAC
• Cambridge (D-500 SE) CDP
• Linn LP12/Adikt/RB300
StereoNut
Quote from: lonewolfny42 on January 16, 2013, 05:33:54 PM
• EE Minimax DAC
Soon as I get everything all hooked up and running!  :)
Found this video...
MOSCODE AMPS.mov
Says...."had to wait a few months for his mod". (in the video)
StereoNut
This may give all of you "techies" (unlike myself!) more of what you're looking for...
Before and after pix!  :thumb:
topround
I hope when it is all hooked  up correctly( don't forget to plug it in) that it sounds glorious.
If it doesn't...don't fret it probably needs a bunch of burn in
get a cheap cd player and run it in repeat mode for a few days, don't worry about the tubes...they need to be burned in as well.
turn it off for a few hours every day
Do it for a week! Sounds crazy but it will sound a lot better
Looks cool Bill! They look well designed. The custom transistor mounting extrusion, huge power transformer, hum buster on the IEC. What are the big tubes?
StereoNut
Quote from: richidoo on January 16, 2013, 06:57:26 PM
Thanks, Rich!  I believe the big tubes are 6LU8's.  I wrote down what the full tube compliment is from when I talked to George Kaye, but don't know where I put my note! :duh
I hooked it up last night and it's sounding pretty good. (Thanks to Tmazz coming over to help.)  I'm sure I'll be in for a roller-coaster ride until the caps settle in, but there's unfortunately no escaping that evil break-in period. :(
Time will tell...
SN
Maybe you should hook it up to Mike's Evolution speakers and break everything in together!
StereoNut
Quote from: BobM on January 17, 2013, 06:08:02 AM
Good one, Bob!  :rofl: :rofl: :rofl:
machinehead
lol... They are running fine now... meanie.
How many watts in that puppy? Are those huge blue things on the right back capacitors. They hold all the immediate power?
Like you I have no idea what anything does... I can try to blow it up 4 you tho.. :)
Its cool ndude.
sleepyguy24
Wow. That is one sweet looking amp. It definitely looks like it was worth the 4 month wait. Also I've done what topround said for break-in. I've bought a Coby or Memorex CDP from Target etc and destroyed it letting it play non-stop to break-in equipment for weeks.
StereoNut
Quote from: machinehead on January 17, 2013, 06:26:34 AM
Yes.  Those power capacitors are MONSTROUS!  The amp is rated at 300WPC into 8ohms. :shock:
