Triode Wire Labs at AXPONA-Chicago
Started by Triode Pete, March 06, 2014, 05:03:00 PM
Triode Pete
Quote from: sleepyguy24 on March 11, 2014, 09:31:23 AM
Hi Pete
How did you come up with the Yamaha, Peachtree and even the Quicksilver monoblocks to pair with the Volti speakers etc? How did the system come together?
Your cables cost more than the Yamaha and Peachtree. Also the Quicksilver monoblocks are a fraction of the cost of Volti Audio speakers. From looking at other shows it always looks like most dealers and manufacturers keep the $$ amount of gear about the same.
Don't get me wrong. I'm glad you have a set-up like this. It shows to people one can have gear at varying price points together producing good sound.
I still need to get past having cables cost more than gear.
Hey Sleepy,
It was Greg Roberts (from Volti Audio) idea to assemble and demonstrate how great speakers & cables can provide top notch hi-fidelity sound from reasonably priced components.
Greg hand-selected the amps, preamp & SACD/CD player. I simply suggested what I've experienced in the past from reputable audio dealers to spend about 10% of your audio budget on real good cabling... Hence, 10% of a $25K total system cost ended-up being my cables, which included four power cables, a set of speaker cables and two sets of interconnect cables... Of course, in the real world, I would offer a "bundled" cable pricing package, which would lower the cost even more...
If you really want an "ear-opening" experience, try substituting the TWL cable loom utilizing the above gear (amps, CD player & preamp) with the included "stock" cords as well as "stock" interconnects and some reasonably priced lamp cord (speaker wire) from Home Depot.
It will not be a subtle difference... more a major difference in SQ. Perhaps then you can consider all the cabling as a vital "component".
My $0.02,
Pete
Triode Pete
Quote from: dflee on March 11, 2014, 01:33:47 PM
Hey Pete, am I correct in assuming there are two sets of interconnects, four pc and a set of sc. Which pc and how long sc?
Does have a lot to do with the price stated.
Really hope to hear the Spirits some time.
Don
Hey Don,
Just noticed your post & question...
Yes, two sets of "Spirit" IC's, two "Eight Plus", one "Ten Plus" and one "Twelve Plus" along with standard speaker cables with the Cardas, "top of the line" bananas (CAB)... Add it up & it's ~ $2493...
Cables subject to change, maybe with a few surprises, as well as the possibility of introducing a PI Audio UberBUSS, to clean-up that nasty hotel power...  :thumb:
Cheers,
Pete
Quote from: Triode Pete on March 14, 2014, 06:46:49 AM
.....as well as the possibility of introducing a PI Audio UberBUSS, to clean-up that nasty hotel power...  :thumb:
That is an excellent idea.
sleepyguy24
Hi Pete. Thanks for clarifying how the system came together. It didn't hit me that the $2500 for cabling was 10% of the budget. I normally follow that rule with a little tweak. I do 10% of what I paid for my gear which is where I came up with my budget. Also thanks everybody who chimed into my question about cables. I need to open up my mind and get past the mental blocks I have about cables.
topround
its sort of like the diamond market...if you understand how that works
whatever the market will bear :thumb:
  Pete if you can bring a couple of Uberbusses. Made a huge difference when we used them at Capitol Audiofest.
   Using one exclusively for digital was key as you remember. An isolation transformer in front of Uber for digital will further improve the presentation as Dave recommended.
